Connect with Winbox or Serial
Hello everyone, I explain to you my problem, I have several routerBOARD 1100 X2 AH on which I launched resets, I heard the small sound of start, I expect the second sound to say that the Router is ready, so from there I branch to administer it via Winbox, I can see it in the tab ‘Neighbors’ unfortunately the one has an ip in 0.0.0.0,
so it is normally possible to connect Via the mac address of the machine but when I try there is an infinite loading time
on the sudden I thought why not trying to connect in Serial by Putty, however it put me that the session is offline And have nothing but a black screen.
So I am looking for a solution, if you have one I am a taker.
I thank you for taking the time to read.
Cordially .
I’m not sure if this is the same or not.. & i don’t know the exact cause…
I’ve had WinBox properly detect neighbor, but fail to connect many times via MAC (same as here) - and my solution was to essentially disable all other NICs in Windows except the one I wanted to connect on. (eventually, might be able to narrow it down to just disabling one or two NICs)
That has worked very consistently for me, I’m not entirely sure what the problem is. Remote chance it’s a conflict with +/-loopback adapter w/Wireshark - not sure?
If it’s not that, either Windows or Winbox is somehow confused on how to route MAC connection to whichever NIC, i’m not entirely sure.
It’s crazy but it works, thanks for the tips
