connecting an Huawei E156G USB 3G modem to RB411U
Hi guys,
I am trying to connect my USB modem to the RB411U, but as for now with no success.
The modem is listed in the system
[admin@TEST_1] > /system resource print
                   uptime: 22m8s
                  version: 5.14
              free-memory: 18300KiB
             total-memory: 29708KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 300MHz
                 cpu-load: 5%
           free-hdd-space: 30920KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 355
         write-sect-total: 95321
               bad-blocks: 0.2%
        architecture-name: mipsbe
               board-name: RB411U
                 platform: MikroTik
[admin@TEST_1] > /system resource print usb
expected end of command (line 1 column 24)
[admin@TEST_1] > /system resource usb print
 # DEVICE VENDOR                                         NAME                                         SPEED
 0 2:1                                                   RB400 EHCI                                   480 Mbps
 1 2:2    HUAWEI Technology                              HUAWEI Mobile                                480 Mbps
 2 1:1                                                   RB400 OHCI                                   12 Mbps
[admin@TEST_1] >
but I do not receive standard modem reply nor on channel=0 nor =1
I know that E156G could be run on 411U as Pilgrim did it here - http://forum.mikrotik.com/t/rb411u-strange-connection-rout-problem-solved/30958/1
I will appreciate any help.
Maybe Pilgrim, as you used E156G on your RB.
EDIT:
It is a double thread. Moderator close this one, please. Leave the linked one open: http://forum.mikrotik.com/viewtopic.php?f=13&t=60614&e=0
