Hi all,
I got some Trouble when I try to connect my external Access-Point to my RB4011 and want to use VLANs with multiple SSIDs.
I connected my AP to a tagged-port and when I use the SSID linked to my standard VLAN everything is fine, but if I want to use a different VLAN for example my vlan30 my mobile devices don’t really use the offered IP-adress they instead complaining about don’t having a internet connection.
Here is my config on the RB4011:
# jan/09/2019 07:58:26 by RouterOS 6.43
# software id = 340C-VRWU
# model = RB4011iGS+
# serial number = 968A095E08F9
add admin-mac=B8:69:F4:99:5D:DA auto-mac=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=e1-wan
set [ find default-name=ether2 ] name=e2-wan
set [ find default-name=ether3 ] name=e3-tagged
set [ find default-name=ether4 ] name=e4-tagged
set [ find default-name=ether5 ] name=e5-tagged
set [ find default-name=ether6 ] name=e6
set [ find default-name=ether7 ] name=e7
set [ find default-name=ether8 ] name=e8
set [ find default-name=ether9 ] name=e9
set [ find default-name=ether10 ] name=e10-untagged
/interface vlan
add interface=bridge name=MGMT vlan-id=99
add interface=bridge name=vlan1 vlan-id=1
add interface=bridge name=vlan20 vlan-id=20
add interface=bridge name=vlan30 vlan-id=30
add interface=bridge name=vlan40 vlan-id=40
add interface=bridge name=vlan50 vlan-id=50
add name=WAN
add name=LAN
add name=dhcp_pool1 ranges=192.168.2.100-192.168.2.200
add name=dhcp_pool20 ranges=172.18.20.100-172.18.20.200
add name=dhcp_pool30 ranges=172.18.30.100-172.18.30.200
add name=dhcp_pool40 ranges=172.18.40.100-172.18.40.200
add name=dhcp_pool50 ranges=172.18.50.100-172.18.50.200
add name=ovpn28 ranges=10.8.0.109-10.8.0.111
add name=ovpn27 next-pool=ovpn28 ranges=10.8.0.105-10.8.0.106
add name=ovpn26 next-pool=ovpn27 ranges=10.8.0.101-10.8.0.102
add name=ovpn25 next-pool=ovpn26 ranges=10.8.0.97-10.8.0.98
add name=ovpn24 next-pool=ovpn25 ranges=10.8.0.93-10.8.0.94
add name=ovpn23 next-pool=ovpn24 ranges=10.8.0.89-10.8.0.90
add name=ovpn22 next-pool=ovpn23 ranges=10.8.0.85-10.8.0.86
add name=ovpn21 next-pool=ovpn22 ranges=10.8.0.81-10.8.0.82
add name=ovpn20 next-pool=ovpn21 ranges=10.8.0.77-10.8.0.78
add name=ovpn19 next-pool=ovpn20 ranges=10.8.0.73-10.8.0.74
add name=ovpn18 next-pool=ovpn19 ranges=10.8.0.69-10.8.0.70
add name=ovpn17 next-pool=ovpn18 ranges=10.8.0.65-10.8.0.66
add name=ovpn16 next-pool=ovpn17 ranges=10.8.0.61-10.8.0.62
add name=ovpn15 next-pool=ovpn16 ranges=10.8.0.57-10.8.0.58
add name=ovpn14 next-pool=ovpn15 ranges=10.8.0.53-10.8.0.54
add name=ovpn13 next-pool=ovpn14 ranges=10.8.0.49-10.8.0.50
add name=ovpn12 next-pool=ovpn13 ranges=10.8.0.45-10.8.0.46
add name=ovpn11 next-pool=ovpn12 ranges=10.8.0.41-10.8.0.42
add name=ovpn10 next-pool=ovpn11 ranges=10.8.0.37-10.8.0.38
add name=ovpn9 next-pool=ovpn10 ranges=10.8.0.33-10.8.0.34
add name=ovpn8 next-pool=ovpn9 ranges=10.8.0.29-10.8.0.30
add name=ovpn7 next-pool=ovpn8 ranges=10.8.0.25-10.8.0.26
add name=ovpn6 next-pool=ovpn7 ranges=10.8.0.21-10.8.0.22
add name=ovpn5 next-pool=ovpn6 ranges=10.8.0.17-10.8.0.18
add name=ovpn4 next-pool=ovpn5 ranges=10.8.0.13-10.8.0.14
add name=ovpn3 next-pool=ovpn4 ranges=10.8.0.9-10.8.0.10
add name=ovpn2 next-pool=ovpn3 ranges=10.8.0.5-10.8.0.6
add name=ovpn1 next-pool=ovpn2 ranges=10.8.0.1-10.8.0.2
add address-pool=dhcp_pool1 disabled=no interface=vlan1 name=dhcp1
add address-pool=dhcp_pool20 disabled=no interface=vlan20 name=dhcp20
add address-pool=dhcp_pool30 disabled=no interface=vlan30 name=dhcp30
add address-pool=dhcp_pool40 disabled=no interface=vlan40 name=dhcp40
add address-pool=dhcp_pool50 disabled=no interface=vlan50 name=dhcp50
/ppp profile
add dns-server=192.168.2.1 local-address=ovpn1 name=ovpn remote-address=ovpn1
/interface bridge nat
add action=accept chain=srcnat
add bridge=bridge interface=e3-tagged
add bridge=bridge interface=e4-tagged
add bridge=bridge interface=e5-tagged
add bridge=bridge interface=e6
add bridge=bridge interface=e7
add bridge=bridge interface=e8
add bridge=bridge interface=e9
add bridge=bridge interface=e10-untagged
/interface bridge vlan
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=1
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=20
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=30
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=40
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=50
add bridge=bridge tagged=bridge,e3-tagged,e4-tagged,e5-tagged vlan-ids=99
add interface=bridge list=LAN
add interface=e1-wan list=WAN
add interface=e2-wan list=WAN
/interface ovpn-server server
set auth=sha1 certificate=rb4011 cipher=aes256 default-profile=ovpn enabled=\
yes max-mtu=1492 port=443 require-client-certificate=yes
add address=192.168.0.2/24 interface=e1-wan network=192.168.0.0
add address=192.168.2.1/24 interface=vlan1 network=192.168.2.0
add address=172.18.20.1/24 interface=vlan20 network=172.18.20.0
add address=172.18.30.1/24 interface=vlan30 network=172.18.30.0
add address=172.18.40.1/24 interface=vlan40 network=172.18.40.0
add address=172.18.50.1/24 interface=vlan50 network=172.18.50.0
add address=192.168.99.1/24 interface=MGMT network=192.168.99.0
set allow-remote-requests=yes servers=192.168.0.1,8.8.8.8
add action=accept chain=forward
add action=accept chain=input
add action=accept chain=output
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
add distance=1 gateway=192.168.0.1
/system clock
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
My access-Point have the ip-adress 192.168.2.12 in vlan1 and is accessible.
When a mobile device books in I can see trafic with torch for VLAN30 and if I look at my DHCP-Server I see an entry where a Lease for VLAN30 was offered, but thats all and its not working.
Do you have any idea where I have to look at?
Thanks in Advance
Martin
