I have a Hex Lite and was using it with Bell Canada's DSL service without issue - I just plugged the output from the modem into Port 1 on the Hexlite and everything worked fine.
Recently I switched to Starlink (Starlink Standard 4 Kit) and it works fine without the Hex lite connected directly via a CAT5 cable to a PC or a switch and then to PCs.
When I connect the same working ethernet cable to the Mikrotik router, the lights on the router turns off and no connection seems to be present.
I have updated the OS on the Hex lite to the latest (7.23.1) and only made the following changes (probably the wrong ones) in QuickSet
Mode Router
Address Acquisition Automatic
Local Network 192.168.88.1
Every other setting is the same as after using Netinstall to start with a fresh configration.
Starlink is not in Bypass mode - I want to get it working with the Hex Lite before doing that, if possible.
Your posted configuration is incomplete (and you should first paste the configuration, then select it and press the button with the </> on it, this way it will become "code").
From what you posted ether1 is not active, but it has to be seen why.
Well, then - for whatever reasons - you have a very partial configuration.
You should try resetting the device to default configuration.
Anyway, it should be something like the one here: https://tangentsoft.com/mikrotik/dir?name=defconf
the file [RB750Pr2.rsc] is for a slightly different model, but configuration for your RB750r2 would be the same.
The configuration on tangentsoft's site is one made with the "terse" option.
I am attaching it below converted as "plain" export format:
# 1970-01-01 00:00:00 by RouterOS 7.15.3
# model = RB750Pr2
add admin-mac=**ELIDED** auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add address-pool=default-dhcp interface=bridge name=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/tool mac-server
/tool mac-server mac-winbox
I tried to reset to default (power up with reset button held, wait for flashing light). I logged in with Winbox and did another export. Same result as before.
I tried again and now I cannot access it with Winbox - all my passwords including blank do not work. I get wrong password messages or timeouts.
This sounds like a power issue of some kind. Are you using the correct power supply?
As for the password, check on the device, is there a sticker? It should have the password on it. If not, where did you buy it? If you bought it used, it could be preconfigured for some specific use and reset just returned it to that.
