I recently started a thread regarding the trunk port configuration in RouterOS. Well, now I have a real world example where I have to configure a trunk port to a provider network, where the provider uses QinQ to transport my traffic. Here’s the provider’s port configuration:
description customerX
switchport
switchport access vlan 2705
switchport trunk encapsulation dot1q
switchport mode dot1q-tunnel
no ip address
logging event link-status
logging event trunk-status
load-interval 30
spanning-tree portfast trunk
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
The way I see it, my traffic will be tagged with a Provider VLAN Tag of 2705 and the provider will accept whatever other VLAN I put, and this is how the QinQ frame will enter the port (P-Tag 2705)(C-tag)(Rest of Ethernet frame)
Based on that and on my previous thread I configured both Mikrotik routers the following way:
Site A
/interface bridge export
add l2mtu=1586 name=br-vlan100
add bridge=br-vlan100 interface=vlan100
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface vlan export
/interface vlan
add interface=ether2 l2mtu=1586 name=vlan100 vlan-id=100
/ip address export
add address=10.27.5.101/24 interface=br-vlan100 network=10.27.5.0
Site B
/interface vlan
add interface=sfp1 l2mtu=1586 name=vlan100 vlan-id=100
/ip address export
add address=10.27.5.100/24 interface=br-vlan100 network=10.27.5.0
And this is supposed to work… but it doesn’t! I’m not able to reach the other end. And the provider says it’s all configured at his end. So I’m kind of stuck with this…
