Connecting Mikrotik via openconnect protocol
Write to the Mikrotik RouterOS developers to add OpenConnect support
I wrote and they responded, but no one asked, so there are no plans to add it, but if more people ask then we will do it, so don’t waste your time, write to support! More people will join, they will add it and then you won’t have to do all these perversions
Write here and tell your friends! https://help.mikrotik.com/servicedesk/servicedesk/customer/portal/1/create/6
Here is the proof of my words
Please REPLY ABOVE THIS LINE ^ (for faster response, use our support portal).
Thank you for contacting MikroTik Support.
Unfortunately, as of this moment, there are no such plans.
When more users request the same addition, we will see what we can do.
We can not make any promises at the moment.
Currently, supported types can be found here:
https://help.mikrotik.com/docs/display/ROS/Software+Specifications#SoftwareSpecifications-VPN
Best regards,
Deniss M.
P.S: All WiFi6 products in stock - check the latest models https://mt.lv/wifi6 and place orders with our distributors!
View this request in our new support portal. Request a password if you have not set it up yet.
I join the request. A very necessary feature.
I also join this and I have created request to support. I can’t understand, why OpenWRT have it for long time, but I can’t use it on my MTs.
I join the request too. A very necessary feature.
So Keenetic have added openconnect client and server in KeeneticOS 4.2.1 to their routers, it was in October 2024. Do you plan to add openconnect support in MTs?
OpenConnect is already supported as an add-on container app service.
I am searching solution too. How to use container to work with openconnect as a client please?
In App: openconnect not found.
We need this core VPN feature, not some 3rd party crutches.
