Sorry if this is obvious to the expert, or has been answered before.
I’ve a station able to connect to either of two APs if I change its configuration appropriately.
Question. If I re-configured the APs to have the same SSDs, frequency and security profiles but different networks could I use WLANs on the station interface to connect to them both simultaneously and link them and their networks?
I know this sounds like WDS but I although both are Miktrotiks as is the station I can only admin the configuration of one of the APs and so can’t set up WDS on it.
It’s not frequency synchronicity (whatever that is ). It’s the way wireless works. a client can only connect to one access point at a time (same goes for DECT, TETRA, GSM, UMTS and practically all other digital wireless systems). An AP can have multiple clients, but a client can only be connected to one AP. What you’re looking to achieve can only be done by:
putting two wireless interfaces in the client router. One interface connecting to each access point.
using WDS
switching the roles over- APs become stations and the station (client) becomes an AP, but then your 2 APs (which are now stations) cannot have other stations (or other APs) connected to them.
