Connecting the BaseBox2 to the netPower 16P.
Is it possible to connect a BaseBox2 to a netPower 16Ppc? It means PoE.
BaseBox2
Max power consumption - 10 W
PoE in - Passive PoE
PoE in input Voltage - 8-30 V
netPower 16P
PoE out - 802.3af/at
Max out per port output (input 18-30 V) - 1.1 A
Max out per port output (input 30-57 V) - 0.6 A
Max total out (A) - 2.8A (18V-30V) & 1.4A (48V-57V) x2 A
If you will use 18V-30V, then yes, there should not be any problems.
The netPower 16P output V will be the same as input V (+ voltage drop).
