Hi guys,
Not sure if I am in the right place, but I am sure this is a beginner question!
I have learnt quite a bit about connecting via Telnet and configuring a remote routerboard 133. (thanks to those that helped!)
I have found a few helpful commands that I execute via Telnet:
notably, /interface wireless scan wlan1 (this shows:)
Mac Address SSID Band Freq Sig NF SNR and RadioName
00:15:6D:93:00:95 TEST 2.4Ghz-b 917 -68 -95 27 SR9Radio
My question is, I have everything configured correctly and I can scan (as above).
In Winbox I can then connect / use this network.
How do I connect via Telnet? Is this command syntax around somewhere:
something like:
/Interface wireless connect SSID=Test ?
Thanks all!
Cheers,
James
Australia
