connecting to LHG LTE6 Modem using Winbox
I am using LHG LTE6 Kit (RBLHGR&R11e-LTE6) on ether1 (passthrough) on my Mikrotik CRS328.
The LTE Modem has internal IP 192.168.1.1/24
The Mikrotik Router 192.168.2.254/24
If there is anything I have to configure on the LTE modem I have to take the cable out of ether1 on the CRS328 and plug it in somewhere else. I have to change my local IP adresse to 192.168.1.x on my PC and now I can connect via winbox to the lte Modem and doing my settings.
Is there a way to connect to the LTE modem via Winbox over the CRS328? So that I dont have to change my local IP address on my computer? I would like to be able to connect to both devices without changing the IP
bests, Christian
There are quite a few posts on this. You can use ROMON or VLANS for management or simply don’t use passthrough.
