connecting to router board via serial
I have a Router board that has not yet been set up. When connecting with Hyper Terminal via the com port, what settings are needed? Also, could someone direct me to the URL on how to upload a mikrotik backup file to the device.
Many thanks in advance.
~James
http://wiki.mikrotik.com/wiki/First_time_startup
http://wiki.mikrotik.com/wiki/Serial_Console
http://www.mikrotik.com/testdocs/ros/3.0/admin/config_content.php#.3
(See export and import)
Tom
Thank you, Tom. This worked perfectly.
Connected via serial, ran ‘setup’, gave the routerboard an IP, connected to RB with winbox, ftp’d backup file from another RB up to the new RB, and restored using winbox.
I have one more question, or maybe two; where can I find a mirror so I can upgrade (running Mikrotik 2.9.23) to the latest OS, 3.20, automatically, and will the upgrade break my current configuration?
Many thanks again for all of your help.
James
Which cable diagram, here is the correct and which is suitable for use with RB532 ?
https://www.mikrotik.lv/testdocs/ros/3.0/admin/serial_content.php
Router Side (DB9f) Signal Direction Side (DB9f)
1, 6 CD, DSR IN 4
2 RxD IN 3
3 TxD OUT 2
4 DTR OUT 1, 6
5 GND - 5
7 RTS OUT 8
8 CTS IN 7
or
1, 4, 6 CD, DTR, DSR LOOP 1, 4, 6
2 RxD IN 3
3 TxD OUT 2
5 GND - 5
7, 8 RTS, CTS LOOP 7, 8
Which RB is suitable with this cable ?
http://wiki.mikrotik.com/wiki/Null_modem_cable
