I’m setting up a Mikrotik Hotspot for the first time and I notice I have to set proxy settings in the browser manually to connect. Is there a setting I’m missing or is it necessary to connect throught the hotspot.
Basically I would like to have someone turn on a laptop and bring up the login page for the microtik without having to set the proxy settings in the browser manually.
You can use web proxy in transparent mode, for more information refer to:
http://www.mikrotik.com/docs/ros/2.8/ip/webproxy.main.8
Thank you for the assistance, but I’m still having problems.
I entered the line that was given on the web page, but it still does not work. I also seem to be having some other problems. I cannot connect to the router ftp, winbox or telnet. I have set everything back to factory defaults went through the instructions. I still cannot do it.
Forget what I said about not being able to connect to winbox. I figured out where I went wrong there.
But that transparent proxy rule for the firewall did not change anything.
Can you post a printout from export command in /ip firewall and /ip web-proxy submenus?
IP Firewall
set input name=“input” policy=accept comment=“”
set forward name=“forward” policy=accept comment=“”
set output name=“output” policy=accept comment=“”
add name=“hotspot-temp” policy=none comment=“limit unauthorized hotspot
clients”
add name=“hotspot” policy=none comment=“account authorized hotspot clients”
/ ip firewall rule forward
add in-interface=wlan1 action=jump jump-target=hotspot-temp comment=“limit
access for unauthorized hotspot clients” disabled=no
add action=jump jump-target=hotspot comment=“account traffic for authorized
/ ip firewall rule hotspot
add action=accept comment=“” disabled=no
/ ip firewall rule hotspot-temp
add flow=hs-auth action=return comment=“return, if connection is authorized”
disabled=no
add protocol=icmp action=return comment=“allow ping requests” disabled=no
add dst-address=:53 protocol=udp action=return comment=“allow dns requests”
disabled=no
add action=jump jump-target=hotspot comment=“reject access for unauthorized
/ ip firewall rule input
add in-interface=wlan1 dst-address=:80 protocol=tcp action=jump
jump-target=hotspot comment=“account traffic from hotspot clients to
hotspot servlet” disabled=no
add in-interface=wlan1 dst-address=:80 protocol=tcp action=accept
comment=“accept requests for hotspot servlet” disabled=no
add in-interface=wlan1 dst-address=:67 protocol=udp action=accept
comment=“accept requests for local DHCP server” disabled=no
/ ip firewall rule output
add src-address=:80 out-interface=wlan1 protocol=tcp action=jump
jump-target=hotspot comment=“account traffic from hotspot servlet to
/ ip firewall dst-nat
add src-address=:80 in-interface=wlan1 dst-address=:8081 protocol=tcp
action=redirect to-dst-port=8081 comment=“transparent HTTP proxy for
add dst-address=:53 protocol=udp action=redirect comment=“intercept all DNS
add in-interface=wlan1 protocol=tcp flow=!hs-auth action=redirect
to-dst-port=80 comment=“redirect unauthorized hotspot clients to hotspot
service” disabled=no
add dst-address=:25 protocol=tcp action=nat to-dst-address=63.98.108.4
comment=“send e-mails through our SMTP server” disabled=no
/ ip firewall service-port
set ftp ports=21 disabled=no
set pptp disabled=no
set gre disabled=no
set h323 disabled=yes
set mms disabled=no
set irc ports=6667 disabled=no
set quake3 disabled=no
set tftp ports=69 disabled=no
/ ip firewall src-nat
add src-address=10.5.50.0/24 action=masquerade comment=“masquerade hotspot
network” disabled=no
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=2m tcp-syn-received-timeout=1m
tcp-established-timeout=5d tcp-fin-wait-timeout=2m
tcp-close-wait-timeout=1m tcp-last-ack-timeout=30s
tcp-time-wait-timeout=2m tcp-close-timeout=10s udp-timeout=30s
udp-stream-timeout=3m icmp-timeout=30s generic-timeout=10m
IP Web-Proxy
/ ip web-proxy
set enabled=no src-address=0.0.0.0 port=3128 hostname=“proxy”
transparent-proxy=no parent-proxy=0.0.0.0:0
cache-administrator=“webmaster” max-object-size=“4096 kB”
cache-drive=system max-cache-size=none
/ ip web-proxy access
add dst-port=!443,563 method=connect action=deny comment=“allow CONNECT only
to SSL ports 443 [https] and 563 [snews]” disabled=no
/ ip web-proxy cache
add url=“cgi-bin \?” action=deny comment=“don’t cache dynamic http pages”
disabled=no
I’ve been messing with the firewall setting this morning, so they may look a little goofed up.
/ ip web-proxy
It seems that you have web-proxy disabled on your router. Maybe you need to re-read the manual…
Ahhhh…
Feeling stupid now and I’m just gonna go with that felling. Thanks for the help
This is what it looks like now
IP Web Proxy
set enabled=yes src-address=0.0.0.0 port=8081 hostname=“proxy”
transparent-proxy=yes parent-proxy=0.0.0.0:0
disabled=no
IP Firewall
clients”
disabled=no
disabled=no
add action=reject comment=“reject access for unauthorized hotspot clients”
disabled=no
add dst-address=:53 protocol=udp action=nat to-dst-address=63.98.108.1
comment=“intercept all DNS requests” disabled=no
add in-interface=wlan1 dst-address=:80 protocol=tcp action=redirect
to-dst-port=80 comment=“transparent HTTP proxy for hotspot clients”
disabled=no
add in-interface=wlan1 dst-address=!10.5.50.1/32:80 protocol=tcp
action=redirect to-dst-port=8081 comment=“” disabled=no
set gre disabled=no
set mms disabled=no
For some reason it still will not work
Nevermind I figured out what I was doing
Thanks for all of your help
