Connecting to Torrent client over LAN
Hi there, just purchased my first MikroTik router hAP ax3, and struggling to connect to my download client over LAN.
First things first, router config (mostly default, but I have been investigating/messing around with this issue for a while now).
# 2025-01-20 14:59:54 by RouterOS 7.17
# software id = xxxxxxx
# model = C53UiG+5HPaxD2HPaxD
# serial number = xxxxxx
add admin-mac=F4:1E:57:4F:27:D9 auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid=xxxxxxx disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.0.0.70-10.0.0.254
add address-pool=dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
/ip dhcp-client
add address=10.0.0.0/24 comment=defconf dns-server=10.0.0.1 gateway=10.0.0.1 \
    netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
add action=accept chain=forward comment="plz qbittorrent" dst-port=8081 \
    protocol=tcp
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=America/Toronto
/system note
set show-at-login=no
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set file-name="filtered port test" filter-interface=ether2 \
    filter-ip-protocol=tcp filter-port=8081 streaming-enabled=yes \
    streaming-server=10.0.0.253
Background on my setup. I have a RaspberryPi that acts as a home server with individual applications running in separate docker containers. If an application needs to be accessed via the UI, I have the ports exposed through docker and the Pi. My download client is a bit more nuanced as it runs its network traffic through another container running a Wireguard tunnel to a Mullvad VPN server. However, it still exposes a local port and should in theory be accessible. Also, this configuration has worked for other routers.
Here are all the listening ports from the Pi
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      956/sshd: /usr/sbin
tcp        0      0 0.0.0.0:8989            0.0.0.0:*               LISTEN      314709/docker-proxy
tcp        0      0 xxxx:52246    0.0.0.0:*               LISTEN      312688/tailscaled
tcp        0      0 0.0.0.0:9696            0.0.0.0:*               LISTEN      315622/docker-proxy
tcp        0      0 xxxx:631           0.0.0.0:*               LISTEN      359748/cupsd
tcp        0      0 0.0.0.0:6969            0.0.0.0:*               LISTEN      381642/docker-proxy
tcp        0      0 0.0.0.0:7878            0.0.0.0:*               LISTEN      315165/docker-proxy
tcp        0      0 0.0.0.0:8096            0.0.0.0:*               LISTEN      312620/jellyfin
tcp6       0      0 :::22                   :::*                    LISTEN      956/sshd: /usr/sbin
tcp6       0      0 ::1:631                 :::*                    LISTEN      359748/cupsd
tcp6       0      0 :::8989                 :::*                    LISTEN      314716/docker-proxy
tcp6       0      0 :::9696                 :::*                    LISTEN      315630/docker-proxy
tcp6       0      0 xxxx::d:64388 :::*                    LISTEN      312688/tailscaled
tcp6       0      0 :::6969                 :::*                    LISTEN      381651/docker-proxy
tcp6       0      0 :::7878                 :::*                    LISTEN      315173/docker-proxy
Also, important to note that I can access ports 7878,9696, and 8989 from my laptop on the LAN.
I have internet access from the Pi itself to the vpn for both the torrent and the vpn tunnel
$ docker exec wireguard curl -s https://am.i.mullvad.net/connected
You are connected to Mullvad (server us-dal-wg-002). Your IP address is 146.70.211.50
$ docker exec qbittorrent curl -s https://am.i.mullvad.net/connected
The wireguard config tunnel contains some Post Up rules taken from this blog https://www.linuxserver.io/blog/routing-docker-host-and-container-traffic-through-wireguard. These could be causing some of the issue, but I’m really not sure how to diagnose that.
PostUp = DROUTE=10.0.0.1; HOMENET=192.168.0.0/16; HOMENET2=10.0.0.0/8; HOMENET3=172.16.0.0/12; ip route add $HOMENET3 via $DROUTE;ip route add $HOMENET2 via $DROUTE; ip route add $HOMENET via $DROUTE;iptables -I OUTPUT -d $HOMENET -j ACCEPT;iptables -A OUTPUT -d $HOMENET2 -j ACCEPT; iptables -A OUTPUT -d $HOMENET3 -j ACCEPT;  iptables -A OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT
PreDown = HOMENET=192.168.0.0/16; HOMENET2=10.0.0.0/8; HOMENET3=172.16.0.0/12; ip route delete $HOMENET; ip route delete $HOMENET2; ip route delete $HOMENET3; iptables -D OUTPUT ! -o %i -m mark ! --mark $(wg show %i fwmark) -m addrtype ! --dst-type LOCAL -j REJECT; iptables -D OUTPUT -d $HOMENET -j ACCEPT; iptables -D OUTPUT -d $HOMENET2 -j ACCEPT; iptables -D OUTPUT -d $HOMENET3 -j ACCEPT
Finally, I ran nmap from the computer I’m trying to use the UI on and keep getting that the port I want is filtered. It does seem strange that the open ports that work aren’t registered by nmap, but I’m not too worried about that.
~% nmap 10.0.0.69 -sV
Starting Nmap 7.95 ( https://nmap.org ) at 2025-01-20 13:21 MST
Nmap scan report for 10.0.0.69
Host is up (0.033s latency).
Not shown: 998 closed tcp ports (conn-refused)
PORT     STATE    SERVICE VERSION
22/tcp   open     ssh     OpenSSH 9.2p1 Debian 2+deb12u2 (protocol 2.0)
6969/tcp filtered acmsoda
Service Info: OS: Linux; CPE: cpe:/o:linux:linux_kernel
I’m truly stumped, and pretty new to networking so any help at all would be extremely helpful. Thanks in advance!
Figured it might be useful to post the firewall rules of the Raspberry Pi server
$ sudo iptables -L
# Warning: iptables-legacy tables present, use iptables-legacy to see them
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy DROP)
DOCKER-USER  all  --  anywhere             anywhere
DOCKER-ISOLATION-STAGE-1  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
DOCKER     all  --  anywhere             anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (5 references)
ACCEPT     tcp  --  anywhere             172.31.0.2           tcp dpt:8989
ACCEPT     tcp  --  anywhere             172.20.0.2           tcp dpt:7878
ACCEPT     tcp  --  anywhere             172.19.0.2           tcp dpt:9696
ACCEPT     tcp  --  anywhere             172.18.0.2           tcp dpt:6969
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2  all  --  anywhere             anywhere
RETURN     all  --  anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-2 (5 references)
DROP       all  --  anywhere             anywhere
Chain DOCKER-USER (1 references)
They seem permissive to me with the required open ports, but I am still new to this so I could be interpreting it incorrectly.
