Dear all,
some weeks ago I ordered 2 of the 951G-2HnD.
I almost spend the recent weekends with configuring them according my needs,
but I got stuck now. Hopefully someone here in this Forum has the hint that I need.
Main Goal:
Basically I want to extend the “Range” of the 3 Wifi Networks with a 2nd 951G-2HnD
but currently only the 192.168.1.0 Network is functional on the 2nd 951G-2HnD
What did I try yet:
- made the ether4 on the 1st to master, assigned 3 VLANS on it in the switching area
- assigned the same 3 VLANs on ether1 on the 2nd one
- created VLAN interfaces with those VLAN IDs and assigned them to the Bridges on the 1st one
same on the 2nd one - on 1st one I kept all firewall settings since it is all working properly on the 1st one connected to the DSL router and the 2 Ethernet networks including the wifi.
- on 2nd one I created allow rules for all so that nothing should have been blocked.
DHCP is configured on the 1st one for all Networks.
The strange thing was that if a device was connected to WLAN1 everything was (and still is without the VLAN settings currently) ok, but if a device is
connected to the WLAN2 or WLAN3 just some Pings go thru and a lot of packets are lost
Please find the network map below (cabling is exactly like on the drawing).
What am I missing ? What could be wrong ? How can I configure the Routerboards to make the wifi networks work ?
Regards
John
