connecting two Cloud router switches with vlans
Hi all,
i have another post, where I don’t get an reply therefore here in a different form
I have a CRS125-24G-1S-2HnD and a CRS326-24G-2S+
both are running routeros 6.47.2
I refer to CRS326-24G-2S+ as switchA and to CRS125-24G-1S-2HnD as switchB
SwitchA ether1 connects to a separate firewall and to the internet
SwitchA has a bridge ether2-19+bond0(ether20-24)( ip range 192.168.199.0/24 and 192.168.200.0/24 ) no vlantaggig for that
SwitchA has a tagged vlan 1003 192.168.168.0/24
SwitchA has a tagged vlan 1010 192.168.1.0/24
SwitchA shall be connected via 4 ports ( bond0) ether20-24 to switchB ports ether1-4
pfsense firewall with DHCP server resides on switchA ether9 for vlan1010 and iprange 192.168.200.0/24 and on ether12 for vlan1003 and iprange 192.168.199.0/24
I want on switchB the same iprange/vlans available as on switch A
eg I plug a device into ether10 and it shall receive an IP address ( range 192.168.[199|200].0/24) form my DHCP server which resides on a pfense firewall connected to switchA (9/12)
in addition the ports ether17-24 shall be untagged for Vlan1010 as the devices can’t do vlantagging but shall be in that specific range ( it shall receive a DHCP lease from my pfsense for vlan1010 )
Any help will be greatly apprecitaed
I tried all different variations of MikroTik examples and forum examples , but it does not work ( especially due to the different hardware I have to use different setups on both SwitchA I can use the bridge with filtering switchB I have to use the switch setup for the vlan filtering )
The CRS1xx should be configured to use the switch https://wiki.mikrotik.com/wiki/Manual:CRS1xx/2xx_VLANs_with_Trunks (the inter-VLAN routing and DHCP server sections are not applicable to your setup), and the CRS3xx should be configured with a single VLAN-aware bridge https://wiki.mikrotik.com/wiki/Manual:CRS3xx_VLANs_with_Bonds
Note that you should use mode=balance-xor transmit-hash-policy=layer-2-and-3 for the CRS3xx bond interface, not mode=802.3ad. It is somewhat confusing that “trunk” can mean either “a connection carrying multiple tagged VLANs” (typically Cisco-speak), or “a static link-aggregation group” (typically HPE-speak) - the CRS1xx trunk is a static link-aggregation group, and in your case will also be carrying multiple tagged VLANs.
You haven’t indicated how you intend to access the switches for management, it can either be with a separate management VLAN as in the examples, or if one of your networks is already used for management functions you can use that.
So on my switchb do I have to setup the trunk and the bond or just the trunk ?
Do I still create the bridge on switchB , If yes ==> I can't add the trunk as it is not shown, if no , what shall I do :slight_smile: ?
on my switch b it would look now like jan/02/1970 03:50:36 by RouterOS 6.47.3
software id = DU55-1G3X
model = CRS125-24G-1S-2HnD
serial number = 744206C4A505
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface ethernet switch trunk
add member-ports=ether1,ether2,ether3,ether4 name=trunk1
/interface ethernet switch egress-vlan-tag
add tagged-ports=trunk1,ether24,switch1-cpu vlan-id=1010
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=1010 ports=ether24
add ports="trunk1,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ethe
r24,switch1-cpu" vlan-id=1010
add address=192.168.199.6/24 interface=ether1 network=192.168.199.0
add address=192.168.1.99/24 interface=ether24 network=192.168.1.0
add action=accept chain=forward log=yes protocol=icmp
and on switch a
sep/15/2020 15:47:46 by RouterOS 6.47.2
software id = FV7D-DRZZ
model = CRS326-24G-2S+
serial number = CDA80C0725D5
add name=bridge1
/interface vlan
add interface=bridge1 name=vlan_1003 vlan-id=1003
add interface=bridge1 name=vlan_1010 vlan-id=1010
add interface=bridge1 name=vlan_1014 vlan-id=1014
/interface bonding
add mode=balance-xor name=bond0 slaves=ether21,ether22,ether23,ether24
/ip hotspot profile
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add bridge=bridge1 interface=ether13
add bridge=bridge1 interface=ether14
add bridge=bridge1 interface=ether15
add bridge=bridge1 interface=ether16
add bridge=bridge1 interface=ether17
add bridge=bridge1 interface=ether18
add bridge=bridge1 interface=ether19
add bridge=bridge1 interface=bond0
add bridge=bridge1 interface=vlan_1010 pvid=1010
add bridge=bridge1 interface=vlan_1003 pvid=1003
add bridge=bridge1 interface=vlan_1014 pvid=1014
add address=192.168.198.1/24 interface=ether1 network=192.168.198.0
add address=192.168.198.2/24 interface=ether1 network=192.168.198.0
add address=192.168.198.3/24 interface=ether1 network=192.168.198.0
add address=192.168.199.1/24 interface=bridge1 network=192.168.199.0
add address=192.168.200.2/24 interface=bridge1 network=192.168.200.0
add address=192.168.168.1/24 interface=vlan_1003 network=192.168.168.0
add address=192.168.1.1/24 interface=vlan_1010 network=192.168.1.0
add address=192.168.198.4/24 interface=ether1 network=192.168.198.0
add address=192.168.198.5/24 interface=ether1 network=192.168.198.0
add address=192.168.198.6/24 interface=ether1 network=192.168.198.0
add address=192.168.198.7/24 interface=ether1 network=192.168.198.0
add address=192.168.198.9/24 interface=ether1 network=192.168.198.0
add address=192.168.198.20/24 interface=ether1 network=192.168.198.0
add action=fasttrack-connection chain=forward comment=
"defconf: fasttrack established,related" connection-state=
established,related
add action=accept chain=forward comment="defconf: accept established,related"
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes
protocol=icmp
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=drop chain=input comment=vlan1003 connection-state="" disabled=yes
dst-address-list=Drop_for_guest log=yes src-address=192.168.168.0/24
add action=drop chain=forward comment=vlan1003 connection-state="" disabled=
yes dst-address-list=Drop_for_guest log=yes src-address=192.168.168.0/24
add action=accept chain=forward disabled=yes dst-address=192.168.179.0/24
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"Allow new connections through router" connection-state=new
add action=reject chain=forward disabled=yes reject-with=
icmp-admin-prohibited
add action=same chain=srcnat same-not-by-dst=no src-address=192.168.199.23
to-addresses=192.168.198.3
add action=same chain=srcnat comment=Louis same-not-by-dst=no src-address=
192.168.199.50-192.168.199.59 to-addresses=192.168.198.5
add action=same chain=srcnat comment=Mel same-not-by-dst=no src-address=
192.168.199.60-192.168.199.69 to-addresses=192.168.198.6
add action=same chain=srcnat comment=Yanic same-not-by-dst=no src-address=
192.168.199.70-192.168.199.79 to-addresses=192.168.198.7
add action=same chain=srcnat comment="Fire_tv;radio" same-not-by-dst=no
src-address=192.168.199.90-192.168.199.99 to-addresses=192.168.198.9
add action=same chain=srcnat comment=Infrastructure same-not-by-dst=no
src-address=192.168.199.200-192.168.199.210 to-addresses=192.168.198.20
add action=same chain=srcnat same-not-by-dst=no src-address=192.168.168.0/24
add action=same chain=srcnat log=yes same-not-by-dst=no src-address=
192.168.199.0/24 to-addresses=192.168.198.1
add action=accept chain=srcnat disabled=yes
add distance=1 gateway=192.168.198.254
/system clock
/system ntp client
set enabled=yes primary-ntp=192.168.200.1 secondary-ntp=192.168.198.254
/system routerboard settings
set boot-os=router-os
/system swos
set allow-from-ports="p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14,p15,p16,p
17,p18,p19,p20,p21,p22,p23,p24,p25,p26" identity=MikroTik3
static-ip-address=192.168.199.6
but it does not work :slight_smile:
I can't reach anything on vlan1010 on switchb or any other ip
You don’t appear to have followed the examples…
Switch B:
Yes, you do need to create a bridge with all of the ports as members. The CRS1xx/2xx link aggregation trunk applies to ports which are already members of the bridge, unlike CRS3xx and non-CRS devices where the ports added to a bond interface must not be members of the bridge.
IP addresses should be applied to VLAN interfaces or the bridge, not ports which are bridge members.
Switch A:
The bridge is not configured to be VLAN-aware. It will pass VLAN tagged traffic in the same way as an unmanged hardware switch does, the pvid= settings under /interface bridge port, and all of /interface bridge vlan settings are ignored.
Do not add VLAN interfaces as members under /interface bridge port.
There are no /interface bridge vlan definitions.
IP addresses should be applied to VLAN interfaces or the bridge, not ports which are bridge members, and why multiple IP addresses on some interfaces?
SwitchA
you mean not VLANs aware as I haven't set the bridge stp to mstp ,
that's because as soon as I enable the bridge filtering nothing works so I have disabled the bridge filtering again, and therefore I had to change it to stp again
i have now added the vlan
[admin@MikroTik] > /interface bridge vlan print detail
Flags: X - disabled, D - dynamic
0 bridge=bridge1 vlan-ids=1010 tagged=vlan_1010,bridge1,bond0 untagged="" current-tagged="" current-untagged=""
SWITCHB
add name=bridge1
/interface wireless
/interface vlan
add interface=ether24 name=vlan1010 vlan-id=1010
add bridge=bridge1 interface=ether20
add bridge=bridge1 interface=ether21
add bridge=bridge1 interface=ether22
add bridge=bridge1 interface=ether23
add bridge=bridge1 interface=ether24
add ports=trunk1,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24,switch1-cpu vlan-id=
1010
add address=192.168.199.6/24 interface=bridge1 network=192.168.199.0
the ip appears on ether24, even though I had specified it to be on vlan_1010 interface
