connecting two different subnet over PTP link route issue.
Connecting two different branches by PTP link. having two RB750 at both side connected by PTP link and network.
Site A:- RB750
add name=bridge1
set [ find default-name=ether2 ] name=Ether2
add address=192.168.245.73/24 interface=ether3 network=192.168.245.0
add address=172.16.0.1/24 interface=Ether2 network=172.16.0.0
add action=masquerade chain=srcnat out-interface=ether3
add distance=1 dst-address=172.16.3.0/24 gateway=192.168.245.71 (PTP Link)
/system routerboard settings
set cpu-frequency=850MHz
Site B- RB750
add name=bridge1
add address=172.16.3.1/24 interface=Ether2 network=172.16.3.0
add address=192.168.245.72/24 interface=ether3 network=192.168.245.0
add distance=1 dst-address=172.16.0.0/24 gateway=192.168.245.70 (PTP Link)
from site A Desktop 171.16.0.20 i can not ping Site B Desktop ip 172.16.3.20
is any route missing.
please help me
Why did you use 192.168.245.70 as the next-hop address in site2? (see the red highlights above)
On Site B, the gateway should be 192.168.245.73
On Site A, the gateway should be 192.168.245.72
Also - remove the NAT rules on the ptp link, unless you really want hosts at 172.16.1.x to see all connections from site A appearing to be from 192.168.245.73 instead of their 172.16.0.x addresses.
hey…thanks a lots…its working removed nat and changed gateway
