connecting two mikrotik "one for PCC and other or hotspot"
Recently Ive wanted to do a small experement to avoid the proplems of hotspot system or pppoe with PPC load balancing
I was thinking about connecting another mikrotik server to work as a hotspot and for filter rules..
however I failed to do that and I dont know why…
is there is special config for both servers or its the ordinary config??
knowng that I use 3.30 version with level 4
thxx
what were symptoms? =)
thank you for ur reply..
actually when I connect the lan of the PCC server as a wan in the second server it gives no traffic .. I checked the cable and tried to change the lan card in both servers but with no advanatge…
if you use Web Proxy, you should operate on ‘output’ chain, not only ‘forward’ for PCC
actually I dnt use web proxy on both servers…
