Connecting Two Mikrotik routers / Two Subnets
Hi All
Can someone help me with the steps through to getting two Mikrotik Routers working together on different subnets.
R1 is (RB2011Uias) works just fine using PPPoE to my Fibre modem. R1 is at 192.168.1.1/24 with DHCP 192.168.1.10 - 192.168.1.30, NAT enabled.
R2 is (RB2011UAS-2HND-IN)
I would like R2 to be using 10.0.1.1/24 with DHCP in that range.
I would like to use ETHER5 on R1 connected to ETHER1 on R2.
All my efforts fail to provide internet access though strangely from within 10.0.1.0 I can ping 192.168.1.1
Any help really appreciated
There’s potential chance for having problems if you want connectivity between devices in different LAN subnets and you want to have firewall between them.
If you want to have it, then the setup will have to be slightly more complicated.
If you won’t allow any connectivity between devices in both subnets, then you’ll have to run firewall on R2 which will block things. In addition to that, you can either run srcnat on R2 (and leave R1 as if there wasn’t R2 with its subnet) or don’t run srcnat on R2 but configure static route on R1 (something like /ip route add dst-address=10.0.1.1/24 gateway=<R2 “WAN” address>).
So my modest (nay novice) skill level still won’t allow traffic to the internet from R2.
Maybe you need something like this?
On R2:
/ip dhcp-client
add comment=uplink dhcp-options=hostname,clientid disabled=no interface=
ether1
add action=masquerade chain=srcnat comment=“Masq LAN” out-interface=
ether1 src-address=10.0.1.0/24
R1
 /export
# oct/06/2019 19:46:44 by RouterOS 6.45.6
# software id = 0273-98QJ
# model = 2011UiAS
# serial number = *******
add admin-mac=D4:CA:******4 auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=*********user=******
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf disabled=yes interface=ether5
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface detect-internet
set detect-interface-list=all
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1 \
    use-peer-dns=no
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes cache-size=4096KiB servers=\
    208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.1.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=******** dst-port=1**8 \
    protocol=udp to-addresses=192.168.**** to-ports=1**8
add action=dst-nat chain=dstnat disabled=yes dst-address=****** dst-port=\
    1** protocol=tcp to-addresses=192.168.**** to-ports=1*****9
add action=dst-nat chain=dstnat disabled=yes dst-address=***** dst-port=\
    8**** protocol=tcp src-port="" to-addresses=192.168.**** to-ports=**
add action=dst-nat chain=dstnat dst-address=***** dst-port=*1 \
    protocol=udp to-addresses=192.168.* to-ports=***
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=stats-all
/system clock
set time-zone-name=Europe/London
/system logging
add prefix=PPPoE topics=pppoe
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether1
R2
[admin@MikroTik] > /export
# jan/02/1970 00:03:42 by RouterOS 6.44.3
# software id = EPF9-8J8D
# model = 2011UAS-2HnD
# serial number = ********
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/ip dhcp-client
add comment=uplink dhcp-options=hostname,clientid disabled=no interface=ether1
add action=masquerade chain=srcnat comment="Masq LAN" out-interface=ether1 \
/system routerboard settings
set cpu-frequency=650MHz
Still nothing.. Sorry guys… BASIC please :unamused:
On R1:
add bridge=bridge comment=defconf disabled=no interface=ether5
This should help you… When you enable ether5 back, try to ping on R2, 8.8.8.8
Basicaly your R2 should get ip from R1 and use it as WAN ip.
If it still not working, please post here export from R2:
/interface bridge export
/ip route export
Thanks of the replies.
I’m afraid neither worked and I thought I’d give a default config a go and BINGO!
R1 Config
# oct/07/2019 20:03:32 by RouterOS 6.45.6
# model = 2011UiAS
# serial number = R1 SERIAL
add admin-mac=R1 MAC auto-mac=no comment=defconf name=bridge
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 password=/////////// user=****************************
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1 use-peer-dns=no
set allow-remote-requests=yes cache-size=4096KiB servers=208.67.222.222,208.67.220.220
/ip dns static
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=ISP IP ADDRESS dst-port= :) protocol=udp to-addresses=192.168.1.75 to-ports= :)
add action=dst-nat chain=dstnat disabled=yes dst-address=ISP IP ADDRESS dst-port= :( protocol=tcp to-addresses=192.168.1.245 to-ports= :(
add action=dst-nat chain=dstnat disabled=yes dst-address=ISP IP ADDRESS dst-port=8080 protocol=tcp src-port="" to-addresses=192.168.1.222 to-ports=???
add action=dst-nat chain=dstnat dst-address=ISP IP ADDRESS dst-port=11941 protocol=udp to-addresses=192.168.1.245 to-ports=?????
/ip service
/lcd
/system clock
/system logging
/tool mac-server
/tool sniffer
R2 Config
# oct/07/2019 20:00:12 by RouterOS 6.44.3
# serial number = *************
add admin-mac=D4:CA********* auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=4 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country="united kingdom" disabled=no distance=indoors \
    frequency=auto frequency-mode=regulatory-domain mode=ap-bridge ssid=\
    "Office LAN" wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=: ) :) :) :)  \
    wpa2-pre-shared-key=:) :) :) :)
add name=dhcp ranges=10.0.0.200-10.0.0.210
add address=10.0.0.1/24 comment=defconf interface=ether2 network=10.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1 netmask=24
/ip dns static
add address=10.0.0.1 name=router.lan
    invalid
    invalid
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
    invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    "defconf: drop everything else not coming from LAN" in-interface-list=!LAN
    invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
    icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
    protocol=udp
    ipsec-ah
    ipsec-esp
/system clock
/system identity
set name="MikroTik Wireless"
/tool mac-server
So thanks all… Does R2 rely on the Firewall settings of R1? I think I have read that correctly?
I checked your configuration of R1 and R2 and i’m totally confused. Your configuration should not work…
On R1 ether5 removed from bridge … and on R2 ether1 used as WAN with dhcp-client on it…it means that R2 will not get WAN ip and will not work.. Are u sure that R2 connected to eth5 on R1? =))
Yes
R1 Ether5 >>>>>> R2 Ether1 :thinking:
DHCP on R1 192.168.1.xxx
DHCP on R2 10.0.0.xxx
I’m wirelessly connected to R2 as I type!
Can you run commands on your R2 and post here output :
/ip route print detail
/ip dhcp-client print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  dst-address=0.0.0.0/0 gateway=192.168.1.1 gateway-status=192.168.1.1 reachable via  ether1 distance=1 scope=30 target-scope=10 vrf-interface=ether1
 1 ADC  dst-address=10.0.0.0/24 pref-src=10.0.0.1 gateway=bridge gateway-status=bridge reachable distance=0 scope=10
 2 ADC  dst-address=192.168.1.0/24 pref-src=192.168.1.37 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10
 0   ;;; defconf
     interface=ether1 add-default-route=yes default-route-distance=1 use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid status=bound address=192.168.1.37/24 gateway=192.168.1.1 dhcp-server=192.168.1.1 primary-dns=192.168.1.1
     secondary-dns=208.67.222.222 expires-after=5m38s
Thank you, this is what i expected to see =)
