Im looking at ways to build in a backup for our core routers, and the stumbling block i keep hitting is transferring the radio configuration. The problem being a failover router will need to have radios in it, in order to keep links up, but i can only connect one antenna to one radio.
Thanks, can you point me in the direction of a splitter that is for this use? all the combiners / splitters ive found are not suitable for this application
In my opinion, use two completely redundant systems, antennas, powersupply etc. Keep it simple and it will work. Backup links I’ve run were this way, one in standby, the other active. I even manually switched them over to keep it simple. I used a pager for failure notice so I could respond quickly if necessary.
Thats all well and good, except many of our links are good two hours drive from where we reside, so a manual switch over would be a huge inefficiency. I had hoped two run to seperate everything with the exception of the antenna. This would help us deal with 99% of problems we encounter
you need this:
1 antenna + dual polarized feedhorn.
3 boards per side
first board simple wds bridge to the other side
second board the same as the first
thirb board uses 2 ethernet ports with bonding over them
you can setup balance-rr for more bandwidth or in your case you need failover link or mode 1/active-backup/.
make sure you put miimon and if one of your board fails the other will take it’s place within less than a second.
I’ve done this using Linux haven’t tested it yet with mikrotik but I’m looking forward to replace my current equipment with mikrotiks.
