Connecting two RB433AHs
I’ve got two RB433AHs that I need to connect.
Unit 1 has a network connected to Ether1.
I want to connect Unit 2 to Ether3 on Unit 1.
Unit 2 has nothing connected to it’s ethernet ports. It received power via the power jack.
I’d like to plug Unit 1 into Ether 1 on Unit 2.
I don’t want to use a switch. ie I want to use a direct connection between the two RBs.
Do I need a straight through or cross over cable?
What do you do with two RB in one place :slight_smile:) Straight or crossover it’s doesn’t matter all new RB have MDI/X support.
3 R52H in one.
2 R52H in the second one.
