I want to have bridge like connection between LAN and Wifi networks. My setup is www → Mikrotik router → LAN(nearly 10 systems connected over 2 eight port switches) and www->Wifi modem → Wifi devices(laptops and tab). There is a server running in LAN and it is accessible for all LAN system. What I want is the server should be accessible for Wifi network as well, how can I do it?
Wifi IP’s
gateway = 192.168.2.1
IP range = 192.168.2.100 - 192.168.2.200.
Mikrotik router’s Interface
[me@MikroTik] /interface> print
# NAME TYPE
0 R ether1-Input ether
1 R ether2 ether
2 R ether3 ether
3 ether4 ether
4 ether5 ether
5 R pppoe-out2 pppoe-out
Mikrotik router’s IP Address:
[me@MikroTik] /ip address> print
# ADDRESS NETWORK INTERFACE
0 192.168.1.1/24 192.168.1.0 ether3
1 192.168.2.1/24 192.168.2.0 ether2
2 D 106.51.173.162/32 106.51.128.1 pppoe-out2
LAN’s 10 system:
I have configured private IP’s for 10 systems manually from 192.168.2.2 to 192.168.2.11.
Gateway for LAN is 192.168.2.1
Things I can do:
I can have a ethernet cable between mikrotkik router and Wifi modem. So 1st port of Mikrotik router would have connected to internet, 2nd to LAN system and 3rd port to Wifi.
Note:
I have two broadband connection.
First broadband connection is connected to Mikrotik router for LAN network.
Second broadband connection is connected to Wifi router for Wifi network. So both the network are independent.
Goal is to make LAN server(192.168.2.10) to be accessible for Wifi network. How can I do this?
I tried with NAT rule as in thinking of ping 192.168.2.10 from Wifi network’s laptop will not find within Wifi network and go for LAN network with following rule in mikrotik router
0 ;;; allow wifi to use lan network
chain=dstnat action=accept src-address=192.168.1.0/24 dst-address=192.168.2.0/24
in-interface=ether3
It’s not working.
