Connection disconnects exactly every 10 min
Hi All,
I have an AP that was working well for some time, then suddenly i noticed that it the connection was dropping. The AP is made of a RB433AH board, Dbii F50 Pro card, now running ROS 6.38.1. The connection to an AP client CPE drops every 10 min exactly. I see in the logs for the Client CPE that a background scan is running when the connection drops. Is there a way to stop the background scan? I did not enable any background scan. thanks
I had also upgraded the CPE to ROS 6.38.1. TX/RX CCQ is mainly at 100/100. SNR 55Db, with Rx level around -53Dbm.
Anyone?
Try to change frequency mode from manual-txpower to superchannel.
