Connection issues with new setup
Hi all!
I have new setup, but still have some issues, that I can not figure out. I would also appreciate the comments about the configuration, if there are some suggestions on improving it.
My Setup:
CHR (QUEMU on Proxmox) RouterOS 7.20.6
WAN-IF connected to DSL modem using PPPoE
LAN-IF connected to cAP ac
cAP ac RouterOS 7.20.6
Proxmox-LAN connected to CHR
Game-LAN connected to hAP ac^2
I use 4 VLANS (later I will set the correct insolation, but by now I want all of them to access internet and be able to communicate with each other).
Admin VLAN (With DHCP) - All Mikrotiks get an address in this VLAN
Home VLAN (With DHCP) - address reservation, DNS forced to use DNS server on CHR with adlists.
IOT VLAN (With DHCP) - address reservation
Guest VLAN (With DHCP) - only DHCP addresses for guests
cAP ac - have virtual AP for each VLAN except Admin. Managed from CAPsMAN on CHR.
With the setup I have following issues
ISSUES
  1. on CHR I can not enable IP/Cloud DDNS - it stuck in Updating. Upgrading RouterOS is possible, ping to 8.8.8.8 succesfull.
  2. on cAP ac I can not access admin interface on Admin VLAN (from Home VLAN using Winbox). I can access, if connecting to MAC address. And I can connect to Admin IP of CHR and hAP ac^2.
  3. on cAP ac I can not access Mikrotik upgrade, (error, Address not available). Ping to 8.8.8.8 succesful.
Things done:
cAP ac & CHR restarted. cAP ac - config backup, reset and deleted config, backup loaded.
CONFIGS
CHR
# 2025-12-10 13:43:01 by RouterOS 7.20.6
# system id = REMOVED
/caps-man channel
add band=2ghz-b/g/n comment=2412 control-channel-width=20mhz frequency=2412 \
    name=CH1 reselect-interval=3h15m save-selected=yes
add band=2ghz-b/g/n comment=2437 control-channel-width=20mhz frequency=2437 \
    name=CH6 reselect-interval=4h30m save-selected=yes
add band=2ghz-g/n comment=2462 control-channel-width=20mhz frequency=2462 \
    name=CH11 reselect-interval=2h45m save-selected=yes
add comment="Common bridge" frame-types=admit-only-vlan-tagged name=\
    DATA-BRIDGE vlan-filtering=yes
set [ find default-name=ether3 ] comment="Configuration interface" \
    disable-running-check=no name=CONFIG-IF
set [ find default-name=ether1 ] comment="ETH to MAIN AP" \
    disable-running-check=no name=LAN-IF
set [ find default-name=ether2 ] comment="ETH to Telekom Modem" \
    disable-running-check=no name=WAN-IF
/interface vlan
add comment="55 Admin VLAN" interface=DATA-BRIDGE name=ADMIN-55 vlan-id=55
add comment="99 Guest VLAN" interface=DATA-BRIDGE name=GUEST-99 vlan-id=99
add comment="77 Home VLAN" interface=DATA-BRIDGE name=HOME-77 vlan-id=77
add comment="88 IOT VLAN" interface=DATA-BRIDGE name=IOT-88 vlan-id=88
add comment="7 Telekom VLAN" interface=WAN-IF name=WAN-7 vlan-id=7
/caps-man datapath
add bridge=DATA-BRIDGE comment="Home Network data" name=HOME-DATA vlan-id=77 \
    vlan-mode=use-tag
add bridge=DATA-BRIDGE client-to-client-forwarding=yes comment=\
    "IOT Network Data" name=IOT-DATA vlan-id=88 vlan-mode=use-tag
add bridge=DATA-BRIDGE comment="Guest Network Data" name=GUEST-DATA vlan-id=\
    99 vlan-mode=use-tag
/interface pppoe-client
add add-default-route=yes comment="Telekom PPPoE" disabled=no interface=WAN-7 \
    max-mru=1492 max-mtu=1492 name=TELEKOM-PPPoE use-peer-dns=yes user=\
    REMOVED
/caps-man security
add authentication-types=wpa-psk,wpa2-psk comment=GUEST-NET encryption=\
    aes-ccm name=GUEST-SEC
add authentication-types=wpa-psk,wpa2-psk comment=HOME-NET encryption=aes-ccm \
    name=HOME-SEC
add authentication-types=wpa-psk,wpa2-psk comment=IOT-NET encryption=aes-ccm \
    name=IOT-SEC
/caps-man configuration
add country=germany datapath=GUEST-DATA installation=indoor mode=ap name=\
    GUEST-CONFIG security=GUEST-SEC ssid=GUEST-NET
add channel=CH6 country=germany datapath=HOME-DATA installation=indoor mode=\
    ap name=HOME-CONFIG security=HOME-SEC ssid=HOME-NET
add country=germany datapath=HOME-DATA installation=indoor mode=ap name=\
    HOME-CONFIG-5G security=HOME-SEC ssid=HOME-NET
add channel=CH11 country=germany datapath=IOT-DATA installation=indoor mode=\
    ap name=IOT-IN-CONFIG security=IOT-SEC ssid=IOT-NET
add channel=CH6 country=germany datapath=IOT-DATA installation=outdoor mode=\
    ap name=IOT-OUT-CONFIG security=IOT-SEC ssid=IOT-NET
add comment="LAN List" name=LAN
add comment="WAN List" name=WAN
add comment="Admin DHCP Pool" name=ADMIN-POOL ranges=\
    192.168.55.10-192.168.55.20
add comment="Home DHCP Pool" name=HOME-POOL ranges=\
    192.168.77.200-192.168.77.254
add comment="IOT DHCP Pool" name=IOT-POOL ranges=\
    192.168.88.200-192.168.88.254
add comment="Guest DHCP Pool" name=GUEST-POOL ranges=\
    192.168.99.2-192.168.99.20
add address-pool=ADMIN-POOL comment="Admin DHCP server" interface=ADMIN-55 \
    lease-time=1w name=ADMIN-DHCP
add address-pool=HOME-POOL comment="Homenet DHCP server" interface=HOME-77 \
    lease-time=1w name=HOME-DHCP
add address-pool=IOT-POOL comment="IOTnetwork DHCP server" interface=IOT-88 \
    lease-time=1w name=IOT-DHCP
add address-pool=GUEST-POOL comment="GuestNet GHCP server" interface=GUEST-99 \
    name=GUEST-DHCP
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
set [ find default=yes ] comment="Ignore other" forbid=yes
add comment="Admin Interface to connect" disabled=no interface=ADMIN-55
/caps-man provisioning
add action=create-dynamic-enabled comment="Main 2.4Ghz" master-configuration=\
    HOME-CONFIG name-format=prefix-identity name-prefix=2G radio-mac=\
    REMOVED slave-configurations=IOT-IN-CONFIG,GUEST-CONFIG
add action=create-dynamic-enabled comment="Main 5Ghz" master-configuration=\
    HOME-CONFIG-5G name-format=prefix-identity name-prefix=5G radio-mac=\
    REMOVED
add action=create-dynamic-enabled comment="Out 2.4Ghz" master-configuration=\
    IOT-OUT-CONFIG name-format=prefix-identity name-prefix=2G radio-mac=\
    REMOVED slave-configurations=HOME-CONFIG,GUEST-CONFIG
add action=create-dynamic-enabled comment="Game 2.4 Ghz" \
    master-configuration=IOT-IN-CONFIG name-format=prefix-identity \
    name-prefix=2G radio-mac=REMOVED slave-configurations=\
add action=create-dynamic-enabled comment="Game 5Ghz" master-configuration=\
    REMOVED
/certificate settings
set builtin-trust-anchors=not-trusted
/dude
set enabled=yes
add bridge=DATA-BRIDGE frame-types=admit-only-vlan-tagged interface=LAN-IF
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=DATA-BRIDGE comment="VLANs on LAN ETH" tagged=DATA-BRIDGE,LAN-IF \
    vlan-ids=77,88,99
add bridge=DATA-BRIDGE comment="Admin VLAN" tagged=DATA-BRIDGE,LAN-IF \
    vlan-ids=55
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
add interface=ADMIN-55 list=LAN
add interface=HOME-77 list=LAN
add interface=IOT-88 list=LAN
add comment="LAN interfaces" interface=GUEST-99 list=LAN
add comment="WAN interface" interface=TELEKOM-PPPoE list=WAN
add comment="ETH port for config" interface=CONFIG-IF list=LAN
add interface=DATA-BRIDGE list=LAN
add address=192.168.55.55/24 comment="Static config IP" interface=CONFIG-IF \
    network=192.168.55.0
add address=192.168.55.1/24 comment="Admin IP" interface=ADMIN-55 network=\
    192.168.55.0
add address=192.168.77.1/24 comment="Homenet IP" interface=HOME-77 network=\
    192.168.77.0
add address=192.168.88.1/24 comment="IOTnet IP" interface=IOT-88 network=\
    192.168.88.0
add address=192.168.99.1/24 comment="Guestnet IP" interface=GUEST-99 network=\
    192.168.99.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add interface=CONFIG-IF
/ip dhcp-server lease
REMOVED
add address=192.168.55.0/24 comment="Admin Net" dns-server=\
    1.1.1.1,8.8.8.8,8.8.4.4 gateway=192.168.55.1 netmask=24
add address=192.168.77.0/24 comment="Home Net" dns-server=192.168.77.1 \
    gateway=192.168.77.1 netmask=24
add address=192.168.88.0/24 comment="IOT Net" dns-server=\
    1.1.1.1,8.8.8.8,8.8.4.4 gateway=192.168.88.1 netmask=24
add address=192.168.99.0/24 comment="Guest Net" dns-server=\
    1.1.1.1,8.8.8.8,8.8.4.4 gateway=192.168.99.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=6h cache-size=40960KiB \
    doh-max-concurrent-queries=200 doh-max-server-connections=20 \
    max-concurrent-queries=1000 max-concurrent-tcp-sessions=40 \
    mdns-repeat-ifaces=GUEST-99,HOME-77,IOT-88 servers=\
    8.8.8.8,8.8.4.4,1.1.1.1 use-doh-server=\
    https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip dns adlist
add url=https://v.firebog.net/hosts/static/w3kbl.txt
add url=\
    https://cdn.jsdelivr.net/gh/hagezi/dns-blocklists@latest/adblock/pro.txt
add url=https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
add url=https://v.firebog.net/hosts/AdguardDNS.txt
add url=https://v.firebog.net/hosts/Easylist.txt
add url=https://v.firebog.net/hosts/Prigent-Crypto.txt
/ip firewall address-list
add address=192.168.55.0/24 comment="Admin network" list=Admin_IP
add address=192.168.77.0/24 comment="Home network" list=Home_IP
add address=192.168.88.0/24 comment="IOT network" list=IOT_IP
add address=192.168.99.0/24 comment="Guest network" list=Guest_IP
    "Defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="Defconf: drop invalid" connection-state=\
    invalid
add action=accept chain=input comment="Defconf: accept ICMP" disabled=yes \
    protocol=icmp
    "Defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
add action=drop chain=input comment="Defconf: drop all not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="Defconf: accept in ipsec policy" \
    ipsec-policy=in,ipsec
add action=accept chain=forward comment="Defconf: accept out ipsec policy" \
    ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="Defconf: fasttrack" \
    "Defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="Defconf: drop invalid" \
    connection-state=invalid
    "Defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="Defconf: masquerade" \
add action=dst-nat chain=dstnat comment="DNS ADblocker" dst-address=\
    !192.168.77.1 dst-port=53 in-interface=HOME-77 protocol=udp src-address=\
    !192.168.77.1 to-addresses=192.168.77.1
    !192.168.77.1 dst-port=53 in-interface=HOME-77 protocol=tcp src-address=\
add action=masquerade chain=srcnat comment="DNS ADblocker" dst-address=\
    192.168.77.1 dst-port=53 protocol=udp src-address-list=Home_IP
/system clock
/system identity
set name=Proxmox-MT
/system scheduler
add comment="Automatic weekly update" interval=1w name=Weekly-Update \
    on-event="/system/script/ run Auto-Update" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=2025-12-06 start-time=03:33:33
/system script
add comment="Automatic weekly upgrade" dont-require-permissions=no name=\
    Auto-Update owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
    system package update\
    \ncheck-for-updates once\
    \n:delay 3s;\
    \n:if ( [get status] = \"New version is available\") do={ install }"
cAP ac
# 2025-12-10 11:33:58 by RouterOS 7.20.6
# software id = REMOVED
# model = RBcAPGi-5acD2nD
# serial number = REMOVED
add frame-types=admit-only-vlan-tagged name=DATA-BRIDGE vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
# channel: 2437/20-Ce/gn(18dBm), SSID: HOME-NET, CAPsMAN forwarding
set [ find default-name=wlan1 ] name=wlan-2G ssid=MikroTik
# channel: 5180/20-Ceee/ac/P(20dBm), SSID: HOME-NET, CAPsMAN forwarding
set [ find default-name=wlan2 ] name=wlan-5G ssid=MikroTik
set [ find default-name=ether2 ] name=GAME-LAN
set [ find default-name=ether1 ] name=PROXMOX-LAN
/interface vlan
add interface=DATA-BRIDGE name=ADMIN-55 vlan-id=55
add interface=DATA-BRIDGE name=GUEST-99 vlan-id=99
add interface=DATA-BRIDGE name=HOME-77 vlan-id=77
add interface=DATA-BRIDGE name=IOT-88 vlan-id=88
add comment="Admin interface" name=Admin
/ip hotspot profile
add bridge=DATA-BRIDGE frame-types=admit-only-vlan-tagged interface=\
    PROXMOX-LAN
add bridge=DATA-BRIDGE frame-types=admit-only-vlan-tagged interface=GAME-LAN
/ipv6 settings
set allow-fast-path=no disable-ipv6=yes forward=no
add bridge=DATA-BRIDGE tagged=DATA-BRIDGE,PROXMOX-LAN,GAME-LAN vlan-ids=\
    77,88,99
add bridge=DATA-BRIDGE tagged=PROXMOX-LAN,DATA-BRIDGE,GAME-LAN vlan-ids=55
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all
add interface=ADMIN-55 list=Admin
/interface wireless cap
set bridge=DATA-BRIDGE caps-man-addresses=192.168.55.1 certificate=request \
    discovery-interfaces=ADMIN-55 enabled=yes interfaces=wlan-2G,wlan-5G
/ip dhcp-client
/system identity
set name=HALL-MT
/system routerboard settings
set auto-upgrade=yes
/system scheduler
add interval=1w name="Auto Upgrade" on-event=\
    "/system/script/ run Auto_Update  " policy=\
    start-date=2025-12-13 start-time=04:30:00
/system script
add dont-require-permissions=no name=Auto_Update owner=admin policy=\
    \n:delay 3s;\
Any comments and improvement suggestions welcome!
First thing I would remove that (set interface-list to none), it may be completely unrelated, but it sometimes does strange things.
also this:
should be disabled (IMHO).
Do on the cap AC names resolve correctly? (i.e. can you ping - besides 8.8.8.8 - also google.com?)
Keep an eye on this page:
https://mikrotikstat.us/
there have been some (brief) interruptions in some services, maybe you were unlucky and mikrotik cloud was down when you tried it.
Hi jaclaz,
Thanks for your comments and especially about the address https://mikrotikstat.us/ - super resource.
I tried your suggested settings:
set detect internet interface to none & disabled auto-upgrade in Routerboard settings. Unfortunately, it did not help.
I tried different Pings and it left me puzzled.
[admin@HALL-MT] > ping 8.8.8.8
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0 8.8.8.8                                    56 119 13ms493us
    1 8.8.8.8                                    56 119 12ms155us
    2 8.8.8.8                                    56 119 12ms317us
    3 8.8.8.8                                    56 119 12ms334us
    4 8.8.8.8                                    56 119 12ms364us
    5 8.8.8.8                                    56 119 12ms319us
    sent=6 received=6 packet-loss=0% min-rtt=12ms155us avg-rtt=12ms497us
   max-rtt=13ms493us
[admin@HALL-MT] > ping www.google.com
    0 142.251.140.164                                              timeout
    1 142.251.140.164                                              timeout
    2 142.251.140.164                                              timeout
    3 142.251.140.164                                              timeout
    4 142.251.140.164                                              timeout
    5 142.251.140.164                                              timeout
    6 142.251.140.164                                              timeout
    7 142.251.140.164                                              timeout
    sent=8 received=0 packet-loss=100%
[admin@HALL-MT] > ping www.mikrotik.com
    0 159.148.172.205                            56  53 39ms847us
    1 159.148.172.205                            56  53 42ms56us
    2 159.148.172.205                            56  53 42ms3us
    3 159.148.172.205                            56  53 39ms879us
    4 159.148.172.205                            56  53 39ms697us
    5 159.148.172.205                            56  53 39ms744us
    sent=6 received=6 packet-loss=0% min-rtt=39ms697us avg-rtt=40ms537us
   max-rtt=42ms56us
[admin@HALL-MT] > ping 142.251.140.164
    sent=6 received=0 packet-loss=100%
[admin@HALL-MT] > ping google.com
    0 216.58.206.46                                                timeout
    1 216.58.206.46                                                timeout
    2 216.58.206.46                                                timeout
    3 216.58.206.46                                                timeout
    4 216.58.206.46                                                timeout
    5 216.58.206.46                                                timeout
    6 216.58.206.46                                                timeout
    sent=7 received=0 packet-loss=100%
[admin@HALL-MT] > ping upgrade.mikrotik.com
    0 159.148.147.251                                              timeout
    1 159.148.147.251                                              timeout
    2 159.148.147.251                                              timeout
    3 159.148.147.251                                              timeout
    4 159.148.147.251                                              timeout
    sent=5 received=0 packet-loss=100%
[admin@HALL-MT] > ping amazon.com
    0 98.87.170.71                                                 timeout
    1 98.87.170.71                                                 timeout
    2 98.87.170.71                                                 timeout
    3 98.87.170.71                                                 timeout
    4 98.87.170.71                                                 timeout
    5 98.87.170.71                                                 timeout
[admin@HALL-MT] > ping amazon.de
    0 3.253.177.16                                                 timeout
    1 3.253.177.16                                                 timeout
    2 3.253.177.16                                                 timeout
    3 3.253.177.16                                                 timeout
    sent=4 received=0 packet-loss=100%
DNS works ok, but some addresses are not reachable.
Sure the MTU is correct? Otherwise you should contact your ISP.
Can you share tracert www.google.com as well?
I believe so. But it is strange that client/router/AP acts differently.
Here is ping from my PC connected to cAP ac Home VLAN. Now the Ping runs also from CHR and cAP ap
>ping www.google.com
Pinging www.google.com [142.250.180.68] with 32 bytes of data:
Reply from 142.250.180.68: bytes=32 time=19ms TTL=116
Ping statistics for 142.250.180.68:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 19ms, Maximum = 19ms, Average = 19ms
Tracing route to www.google.com [142.250.180.68]
over a maximum of 30 hops:
  1    <1 ms     1 ms    <1 ms  192.168.77.1
  2     5 ms     5 ms     6 ms  p3e9bf36b.dip0.t-ipconnect.de [62.155.243.107]
  3    12 ms    13 ms    31 ms  f-ed11-i.F.DE.NET.DTAG.DE [217.0.192.162]
  4    15 ms    14 ms    14 ms  62.157.250.46
  5    16 ms    15 ms    16 ms  192.178.109.243
  6    15 ms    13 ms    13 ms  192.178.109.216
  7    16 ms    15 ms    16 ms  209.85.252.214
  8    21 ms    20 ms    20 ms  192.178.75.104
  9    21 ms    20 ms    21 ms  108.170.232.43
 10    19 ms    18 ms    19 ms  192.178.106.177
 11    23 ms    46 ms    20 ms  142.251.239.183
 12   574 ms   195 ms    45 ms  ber07s03-in-f4.1e100.net [142.250.180.68]
Trace complete.
If I check upgrade.mikrotik.com
on client
Pinging global-balancer-e.mikrotik.com [159.148.147.251] with 32 bytes of data:
Reply from 159.148.147.251: bytes=32 time=36ms TTL=53
Reply from 159.148.147.251: bytes=32 time=58ms TTL=53
Reply from 159.148.147.251: bytes=32 time=243ms TTL=53
Reply from 159.148.147.251: bytes=32 time=35ms TTL=53
Ping statistics for 159.148.147.251:
    Minimum = 35ms, Maximum = 243ms, Average = 93ms
>tracert
Tracing route to global-balancer-e.mikrotik.com [159.148.147.251]
  1    40 ms    17 ms     2 ms  192.168.77.1
  2     7 ms     6 ms     6 ms  p3e9bf36b.dip0.t-ipconnect.de [62.155.243.107]
  3   464 ms    12 ms    11 ms  f-ed11-i.F.DE.NET.DTAG.DE [217.0.192.134]
  4   294 ms    26 ms    12 ms  ffm-b5-link.ip.twelve99.net [62.115.172.70]
  5    13 ms    12 ms   638 ms  ffm-bb2-link.ip.twelve99.net [62.115.136.218]
  6    32 ms    30 ms     *     sto-bb2-link.ip.twelve99.net [62.115.138.104]
  7   342 ms    36 ms    35 ms  riga-b5-link.ip.twelve99.net [62.115.142.191]
  8   328 ms    38 ms    36 ms  siatet-ic-332270.ip.twelve99-cust.net [213.248.84.33]
  9     *        *        *     Request timed out.
 10     *        *        *     Request timed out.
 11     *        *        *     Request timed out.
 12    35 ms    36 ms    35 ms  159.148.147.251
Trace complete.
On CHR
[admin@Proxmox-MT] > ping upgrade.mikrotik.com
    0 159.148.147.251                            56  54 35ms205us
    1 159.148.147.251                            56  54 35ms410us
    sent=2 received=2 packet-loss=0% min-rtt=35ms205us avg-rtt=35ms307us max-rtt=35ms410us
[admin@Proxmox-MT] > tool traceroute upgrade.mikrotik.com
ADDRESS                          LOSS SENT    LAST     AVG    BEST   WORST STD-DEV STATUS
62.155.243.107                     0%    3   4.7ms   250.6     4.7   381.7     174
217.0.192.134                      0%    3  10.2ms    36.9    10.1    90.5    37.9
62.115.172.70                      0%    3  11.9ms    22.1    11.9    42.3    14.3
62.115.136.218                     0%    3    12ms    12.4      12    12.7     0.3
62.115.138.104                   33..    3 timeout    28.6    28.5    28.6     0.1
62.115.142.191                     0%    3  34.5ms    34.7    34.5    34.9     0.2
213.248.84.33                      0%    3  35.7ms    35.8    35.7    35.9     0.1
                                 100%    3 timeout
                                 100%    3 timeout
                                 100%    3 timeout
159.148.147.251                    0%    2  34.3ms    36.6    34.3    38.9     2.3
and on cAP ap
Can you give an updated export from the cAP ac?
This is the actual export
# 2025-12-10 14:35:35 by RouterOS 7.20.6
/interface wireless
/interface vlan
/ip hotspot profile
    PROXMOX-LAN
/ipv6 settings
    77,88,99
set lan-interface-list=all
/ip dhcp-client
/system identity
set name=HALL-MT
/system scheduler
/system script
    \n:delay 3s;\
Hmmm, it should AFAICR be set to:
set detect-interface-list=none
(again, possibly unrelated to the issue you are experiencing, still ...)
Here is probably the root of your problem, on the CHR. If you run:
/ip route print
(or look at the IP -> Routes table in WinBox) you'll probably see that there are two connected routes with the destination dst-address=192.168.55.0/24 with two different gateways, one gateway=CONFIG-IF and one with gateway=ADMIN-55. They will have the same distance and you'll see a + sign in the flag column.
What you created was an ECMP group. Depending on the source and destination addresses of the packets, packets with destination in the 192.168.55.0/24 range will now sometimes be sent to the ether3 port (CONFIG-IF), sometimes to the VLAN interface.
That's the reason why depending on the ping destination, sometimes you get responses, and sometimes not. The response packets of the requests will have a 50% chance of be sent to ether3 and never reach your cAP. ECMP by default (in the L3 mode) calculates the hash based on the source address and the destination address, then picks one of the two routes with the + sign depending on the hash value.
So when 192.168.55.10 pings 8.8.8.8 the calculated hash might cause the response to land on the route with gateway=ADMIN-55, and it works, but pinging 1.0.0.1 will produce a hash that sends the response to the route with gateway=CONFIG-IF and you get the timeout because the packets never get back to 192.168.55.10.
As a fix, you should modify the subnet assigned to CONFIG-IF, so that the connected route created no longer forms an ECMP group with the 192.168.55.0/24 route.
Thanks CGGXANNX !
You are right! It solved the issues with 192.168.55.0/24 network.
I just removed the IP address from the config interface and all now works perfectly fine!
Only issue is still with DDNS on CHR. I want to get it working for WireGuard (Sad that BTH is not working on CHR)
Thanks also @jaclaz & @erlinden for your input!
I only have the free CHR license on my VMs so I cannot test that, but make sure that you've activated your CHR license so that it's recognized as a paid & perpetual license for IP->Cloud to work. Not the trial (60-day) license and not the free (that limits everything to 1 Mbps) license.
Aha! I still use trial licence for setup and testing. Will check when it will be properly set up.
Thanks!
