Hi folks,
P2P connections are causing big problems to my network.
When the P2P traffic is more intense my client's latency grows up too, and all other services are affected.
I try to solve this problem limiting my client's connections with the following rules:
rule 1
chain=forward protocol=tcp
connection-limit=25,32 connection-state=new action=drop
rule 2
chain=forward protocol=udp dst-port=!53 limit=1,1 action=drop
My intention is to limit the connections of each client to 25, and also the UDP !53 to 1/second.
With those rules my problem is solved for some days. But, suddenly, my clients cannot access any site until my router reboot. I think that those rules maybe are treating other kinds of traffic.
What rules are you guys using to limit connections?
Thanks a lot
I had the same problem here and solved it using the MANGLE table to mark TCP and UDP packages which are using ports higher then 1024 with a specific flag. Then, I created a queue with limited speed and selected the packages with the same flag used before to fall down on it. On the MANGLE table I also created rules for exceptions (services using high ports that should not be limited by the queue).
With this rules our clients can keep using P2P applications but the speed available for it does not affect the performance of the access point.
Another important tip is create rules on the FILTER table to block NETBIOS packages, broadcasts, packages to invalid networks and this kind of stuff.
You can also specify in your MANGLE rules that it should be applied only on specific times so your clients can keep using P2P applications at night while the traffic is not so intense.
I hope it help you… Please give us a feedback about your situation.
Gabriel Lauter
Brazil
Hi Gabriel,
Thanks for your reply.
I’m testing these rules today and they’re working fine for me.
Thanks again
Jorge
nick52
September 12, 2007, 4:35pm
4
Hi gabriellauter,
may you detail better the rules that you applied, please?
thanks,
nick52
sorry about the time between posts… here goes my current setup…
[admin@MikroTik] > /ip firewall mangle print
0 ;;; teste de ping
chain=input action=mark-packet new-packet-mark=icmp passthrough=no dst-address=200.200.200.9
1 chain=output action=mark-packet new-packet-mark=icmp passthrough=no src-address=200.200.200.9
2 chain=prerouting action=mark-packet new-packet-mark=icmp passthrough=no dst-address=200.200.200.202
3 chain=prerouting action=mark-packet new-packet-mark=icmp passthrough=no src-address=200.200.200.202
4 ;;; voip
chain=prerouting action=mark-packet new-packet-mark=voip passthrough=no src-address=200.200.200.0/24 dst-port=5060 protocol=udp
5 chain=prerouting action=mark-packet new-packet-mark=voip passthrough=no src-address=200.200.200.0/24 dst-port=10000-12000 protocol=udp
6 chain=prerouting action=mark-packet new-packet-mark=voip passthrough=no dst-address=200.200.200.0/24 src-port=5060 protocol=udp
7 chain=prerouting action=mark-packet new-packet-mark=voip passthrough=no dst-address=200.200.200.0/24 src-port=10000-12000 protocol=udp
8 ;;; msn
chain=prerouting action=accept dst-port=1863 protocol=tcp
9 chain=prerouting action=accept src-port=1863 protocol=tcp
10 ;;; veneza, webcam da dani
chain=prerouting action=accept src-address=200.200.200.66
11 chain=prerouting action=accept dst-address=200.200.200.66
12 ;;; jogo diablo cliente marselha
chain=prerouting action=accept src-address=200.200.200.55 dst-port=6112-6119 protocol=tcp
13 chain=prerouting action=accept src-address=200.200.200.55 dst-port=6112-6119 protocol=udp
14 chain=prerouting action=accept dst-address=200.200.200.55 src-port=6112-6119 protocol=tcp
15 chain=prerouting action=accept dst-address=200.200.200.55 src-port=6112-6119 protocol=udp
16 chain=prerouting action=accept src-address=200.200.200.55 dst-port=4000 protocol=tcp
17 chain=prerouting action=accept src-address=200.200.200.55 dst-port=4000 protocol=udp
18 chain=prerouting action=accept dst-address=200.200.200.55 src-port=4000 protocol=tcp
19 chain=prerouting action=accept dst-address=200.200.200.55 src-port=4000 protocol=udp
20 ;;; p2p_up
chain=prerouting action=mark-packet new-packet-mark=p2p_up passthrough=no src-address=200.200.200.0/24 dst-port=1025-65535 protocol=tcp
time=8h-23h,sat,fri,thu,wed,tue,mon,sun
21 chain=prerouting action=mark-packet new-packet-mark=p2p_up passthrough=no src-address=200.200.200.0/24 dst-port=1025-65535 protocol=udp
22 ;;; p2p_down
chain=prerouting action=mark-packet new-packet-mark=p2p_down passthrough=no dst-address=200.200.200.0/24 src-port=1025-65535 protocol=tcp
23 chain=prerouting action=mark-packet new-packet-mark=p2p_down passthrough=no dst-address=200.200.200.0/24 src-port=1025-65535 protocol=udp
[admin@MikroTik] > /ip firewall filter print
0 ;;; bloqueios virus e worms
chain=forward action=drop dst-address=192.168.0.0/16
1 chain=forward action=drop dst-address=172.16.0.0/16
2 chain=forward action=drop dst-address=10.0.0.0/8
3 chain=forward action=drop dst-address=255.0.0.0/8
4 chain=forward action=drop dst-port=135-139 protocol=tcp
5 chain=forward action=drop dst-port=445 protocol=tcp
6 chain=forward action=drop dst-port=135-139 protocol=udp
7 chain=forward action=drop dst-port=445 protocol=udp
[admin@MikroTik] > /queue simple print
0 name="Compusat" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=icmp direction=both priority=1 queue=default-small/default-small
limit-at=0/0 max-limit=0/0 total-queue=default-small
1 name="VoIP" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=voip direction=both priority=1 queue=default-small/default-small limit-at=0/0
2 name="p2p_up" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=p2p_up direction=both priority=8 queue=wireless-default/wireless-default
limit-at=1000/1000 max-limit=150000/150000 total-queue=default-small
3 name="p2p_down" dst-address=0.0.0.0/0 interface=all parent=none packet-marks=p2p_down direction=both priority=8 queue=wireless-default/wireless-default
limit-at=1000/1000 max-limit=300000/300000 total-queue=default-small
4 name="itapema" target-addresses=200.200.200.91/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=5
queue=wireless-default/wireless-default limit-at=250000/500000 max-limit=250000/500000 total-queue=default-small
5 name="paraty" target-addresses=200.200.200.123/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=5
queue=wireless-default/wireless-default limit-at=128000/256000 max-limit=128000/256000 total-queue=default-small
... [supressed lines...]
26 name="inconfidente" target-addresses=200.200.200.40/32 dst-address=0.0.0.0/0 interface=all parent=none direction=both priority=5
good luck,
gabriel lauter
chain=forward action=drop tcp-flags=syn protocol=tcp src-address=9.9.8.0/24
this will do for udp and tcp you can change values
