Connection marking in mangle
Hi. Trying to give higher priority to 1433 port connections. First i mark all traffic as class-d, then select 1433 port (actualy it can be any port) and mark as class-a. Next i suppose to mark packets of both connection marks and build a queue. But when i monitor IP-FIERWALL-CONNECTIONS with 1433 port filter, i see some connections as class-a and some as class-d. The same thing is on the other router. Why is that so?
add action=mark-connection chain=forward comment=ALLTRAFFIC disabled=no new-connection-mark=CLASS-D passthrough=yes
add action=mark-connection chain=forward comment=SQL disabled=no dst-port=1433 new-connection-mark=CLASS-A passthrough=yes protocol=tcp
When you are using passthrough if your connection would match another connection lower down it will get remarked. It can’t have multiple connection marks.
Exactly, class-d mark is higher in the list than class-a, so all traffic first gets class-d mark and when a connection matches another condition (1433 port) it should change its mark to class-a. Most of the cnnections do this but some stay as class-d. What am i doing wrong?
It might be in the wrong chain. Check the packet flow to see what chain you should be in.
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
Mark using the prerouting chain?
I have SRC_NAT enabled so i guess i need to use postrouting chain but it changes nothing. I tried all chains for both types of traffic.
all the traffic is already marked with no-mark packet/connection mark, so you are just wasting a lot of resources on something you do not have to do at all.
are those in the beginning all the mangle rules there is?
Ok, i thouhgt about this but anyway when i’m disabling “alltraffic” marker and having more different classes (class-b, class-c connections) some connetcions to the port 1433 become class-c and class-b as you can see on the screenshot.
I never thought about this… :open_mouth:
So if you have a ‘base’ priority you don’t really need a rule, you just need a queue that grabs no_mark. :sunglasses:
