I can’t find it via Winbox, but it was start i listen the dual beep, as it work. So R series don’t have Serial port for console, how i can connect it via JTAG? or may be having the other way?
P.S> The reset button was not help…
try using Winbox via MAC. By default it should have IP 192.168.88.1 on the ethernet interface.
I try it, nothing to answer
i fix my problems with the follow link:
http://wiki.mikrotik.com/wiki/MikroTik_Password_Recovery
I use the other reset button ![]()
If the board beeps twice it means that the RouterOS is running.
So if you have ethernet cable connectoed to the board from your PC, you should be able to see the MAC address of the board from the Winbox if you press on the “…” button.
