Connection problems
Basically, I experience some connection issues when using my Mikrotik router. For example, when I plug my internet cable directly into PC, ForHonor in-game menu shows open NAT type, best quality connection, but when I plug internet cable to the router and then use LAN cable to connect my PC to the router, it changes to moderate NAT type and I sometimes get disconnected from servers. I’ve tried to play with settings of the router, but it seems like nothing helps. I can’t have internet cable plugged into PC all the time since I need Wi-Fi as well, so either you guys may have an idea how to fix this (ports are excluded, it’s not because of them) or mb you can just tell me how to connect my PC to the internet via the router without using any of the router`s functions (like through the access point)
