connection problems
on the log
03:07:26 wireless,info 00:0C:42:05:E4:B5@wlan1: failed to connect, on 5180, authentication timeout
03:07:39 wireless,info 00:0C:42:05:E4:B5@wlan1: failed to connect, on 5180, authentication timeout
03:07:53 wireless,info 00:0C:42:05:E4:B5@wlan1: failed to connect, on 5180, authentication timeout
03:08:07 wireless,info 00:0C:42:05:E4:B5@wlan1: failed to connect, on 5180, authentication timeout
if i scan ny wlan interface i can see my ssid that i need to connect to i connect to it but i keep getting the above error message i n my log
can any one help me
ap-------------sation
i have 2 other stations connected to the same ap
and thay work fine
It is likely a bad signal problem.
Please let us know what the signal strength’s of all connected clients are and which one is giving the problem. Also give us the signal level on both sides (both the highsite and client side).
Do you have clear line of site (LOS) from the problem site to your highsite? Sometimes you have great signal from the one site to the other, but not vice versa. This is a typical problem when using high powered cards on highsites but not at clients.
