Connection refused
I’ve seen this question asked before but have seen no solutions. I have a 2.9.24 RouterOS unit whose ethernet IP I can access no problem via SSH, WWW, FTP etc. but I can’t connect using Winbox on the same IP. I can connect using Winbox on it’s Wireless interfaces okay but not on its ethernet interface.
Check if there is some firewall rule that is blocking port TCP 8291..
Regards
Thanks Cibernet but the only firewall entry of any kind that I can see is :
chain=srcnat out-interface=ether1 action=masquerade
which is there so that I can share the Public IP on the wireless interfaces.
Ummm… that`s strange… what version of the Winbox loader are you using?
The Winbox loader is V2.2.8 freshly provided by the RouterOS itself. I’ve also tried clearing out the C:\Documents and Settings\username\Application Data\Mikrotik\Winbox folder first a few times but it makes no difference. I can provide an SSH login if that would be of any use?
If you are using MT 2.9.24 the winbox loader should be 2.2.10..
Thanks Cibernet, I was running 2.2.8 using a shortcut to a previous download. Anyway I’ve dowloaded Winbox again from the node and when I connected it downloaded the plugins but I still get the same error. I can still connect via wireless using Winbox 2.2.9 and 2.2.10 and I can still connect via web and SSH.
Anyone else got any idea why I always get “connection refused” when I try to connect to the public IP of the RouterOS using Winbox?
Do you have transparnt proxy on?
I read that may be a problem
Thanks Equis, there are no proxies on (see below). When I try to connect, it looks initially like it will work but then refuses. Does anyone know exactly what situation will cause Winbox to display the message "Connection Refused"?
user@MikroTik] ip proxy> print
enabled: no
port: 8080
parent-proxy: 0.0.0.0:0
maximal-client-connecions: 1000
maximal-server-connectons: 1000
user@MikroTik] ip web-proxy> print
enabled: no
src-address: 0.0.0.0
port: 3128
hostname: "proxy"
transparent-proxy: no
cache-administrator: "webmaster"
max-object-size: 4096KiB
cache-drive: system
max-cache-size: none
max-ram-cache-size: unlimited
status: stopped
reserved-for-cache: 0KiB
reserved-for-ram-cache: 2048KiB
does your user settings allow to connect through winbox?
I assume so. I wouldn’t even know how to resrict this. I can connect to both wireless interfaces using Winbox. The problem only exists on the ethernet interface. I can connect to the ethernet interface using www and ssh.
