I have a Mikrotik RB951 with several client computer.
I have problems with client that want to access a public FTP.
All my FTP client behind the Mikrotik, receive a “Connection reset by peer” error. Authentication goes well, but as soon as I use the mput command the error appears.
When I remove the mikrotik and replace it with a Comtrend ADSL router it works.
The mikrotik FTP service is disabled.
I even change the port in order to be sure.
I have created a rule that allows all forward traffic for the ip of the FTP server, but still nothing. I always get the same mistake.
Did you have an idea please?
Thanks.
