makbar
November 14, 2017, 11:40pm
1
I understand Cisco config
ip access-list extended WAN-IN
permit tcp any any established
but not understand MikroTik default FW record
add action=accept chain=input connection-state=established
without TCP.
What is “state=established” for non TCP protocols?!
jarda
November 15, 2017, 3:18am
2
This state is of connection in connection table of the firewall and has nothing to do with the protocol itself.
makbar
November 15, 2017, 9:44am
3
When this state occurs or disappears with non-TCP protocols, for example GRE, ICMP, UDP…
blajah
November 15, 2017, 10:39am
4
Its explained in ConTrack settings
/ip firewall connection tracking> pri
enabled: yes
tcp-syn-sent-timeout: 5s
tcp-syn-received-timeout: 5s
tcp-established-timeout: 1d
tcp-fin-wait-timeout: 10s
tcp-close-wait-timeout: 10s
tcp-last-ack-timeout: 10s
tcp-time-wait-timeout: 10s
tcp-close-timeout: 10s
tcp-max-retrans-timeout: 5m
tcp-unacked-timeout: 5m
udp-timeout: 10s
udp-stream-timeout: 3m
icmp-timeout: 10s
generic-timeout: 10m
max-entries: 218008
total-entries: 55
Additional comment regarding gre. If 2 sides agree on setting up tunnel ( no matter what protocol it is) all connection-state mechanics is described inside tunnel itself. External factors like ConnectionTracker would cause more harm then good, interfering with tunnel protocol mechanisms.
