Hi everybody,
I´m a Mikrotik APs user since March of this year. I´m not a super networking guy and I have problems with my two APs that are controlled by the ohter AP throug Capsman (so 3 in total).
From time to time I have no Internet on my APs only on the one that is running Capsman Server. I can see that a connetction to the AP is made but I get the information “Internet not working” on my phone or my Laptop. I have no clue how to solve this and I´m asking kindly for your help.
I made an export of the setting of 1 AP and of the one that is running the Capsman Server. Could you please check this and give me a hint?
Thanks a lot!
AP (not running Capsman Server)
export compact
aug/03/2020 15:48:15 by RouterOS 6.46.4
software id = 00TA-WKW3
model = RBcAPL-2nD
serial number = BB220B66102F
add admin-mac=C4:AD:34:1C:2A:D0 auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
managed by CAPsMAN
channel: 2412/20-Ce/gn(18dBm), SSID: stubbishome, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
add name=WAN
add name=LAN
/ip hotspot profile
add bridge=bridgeLocal comment=defconf interface=ether1
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes interfaces=
wlan1
/ip dhcp-client
add comment=defconf disabled=no interface=bridgeLocal
/system clock
/system identity
set name=Untergeschoss
And the one that is running Capsman Server:
export compact
may/18/1970 22:37:35 by RouterOS 6.46.4
software id = YBS5-1W1P
model = RBcAPGi-5acD2nD
serial number = B9320B417A79
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz frequency=2432 name=2,4_EG
add band=2ghz-g/n control-channel-width=20mhz frequency=2472 name=2,4_OG
add band=2ghz-g/n control-channel-width=20mhz frequency=2412 name=2,4_UG
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=germany disabled=no
frequency=2432 installation=indoor mode=ap-bridge ssid=stubbishome
wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-eCee
country=germany frequency=5240 mode=ap-bridge ssid=stubbishome
/caps-man interface
add disabled=no l2mtu=1600 mac-address=C4:AD:34:8A:4E:B2 master-interface=none
name=cap28 radio-mac=C4:AD:34:8A:4E:B2 radio-name=C4AD348A4EB2
/caps-man datapath
add bridge=bridge1 client-to-client-forwarding=yes local-forwarding=yes name=
datapath1
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm
group-encryption=aes-ccm name=“Sicherheitseinstellung”
passphrase=stefanisttoll
/caps-man configuration
add channel=2,4_EG country=germany datapath=datapath1 installation=indoor mode=
ap name=“2,4 EG” security=“Sicherheitseinstellung” ssid=
stubbishome
add channel=2,4_OG channel.band=2ghz-g/n channel.control-channel-width=20mhz
channel.frequency=2472 country=germany datapath=datapath1 installation=
indoor mode=ap name=“2,4 OG” security=“Sicherheitseinstellung”
ssid=stubbishome
add channel=2,4_UG channel.band=2ghz-g/n channel.control-channel-width=20mhz
channel.frequency=2412 country=germany datapath=datapath1 installation=
indoor mode=ap name=“2,4 UG” security=“Sicherheitseinstellung”
ssid=stubbishome
/caps-man interface
add channel=2,4_OG configuration=“2,4 EG” disabled=no l2mtu=1600 mac-address=
C4:AD:34:8A:4E:B1 master-interface=none name=MikroTik-1 radio-mac=
C4:AD:34:8A:4E:B1 radio-name=C4AD348A4EB1
add channel=2,4_UG configuration=“2,4 EG” disabled=no l2mtu=1600 mac-address=
C4:AD:34:1C:2A:D1 master-interface=none name=Untergeschoss-1 radio-mac=
C4:AD:34:1C:2A:D1 radio-name=C4AD341C2AD1
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“” mode=
dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=stefanisttoll
/ip hotspot profile
/caps-man access-list
add action=accept allow-signal-out-of-range=5s client-to-client-forwarding=yes
disabled=no interface=all signal-range=-80..120 ssid-regexp=“”
add action=reject allow-signal-out-of-range=10s client-to-client-forwarding=yes
disabled=no interface=all signal-range=-120..-81 ssid-regexp=“”
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-enabled hw-supported-modes=g master-configuration=“2,4 EG”
name-format=prefix-identity radio-mac=C4:AD:34:9E:8C:A8
add action=create-dynamic-enabled master-configuration=“2,4 UG” name-format=
prefix-identity radio-mac=C4:AD:34:1C:2A:D0
add action=create-dynamic-enabled master-configuration=“2,4 OG” name-format=
prefix-identity radio-mac=C4:AD:34:8A:4E:AF
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
set bridge=bridge1 discovery-interfaces=bridge1 interfaces=wlan1,wlan2
/system identity
set name=“Verwaltung EG”
