Connection to wireless network with mAP 2n
I follow guide on the wiki : https://wiki.mikrotik.com/wiki/Connect_to_an_Available_Wireless_Network
Acces point is ASUS router, I configured a Mikrotik mAP 2n following the guide. I am connected to mAP 2n with notebook by ethernet cable to ETH2 port.
Export of configuration is following:
[admin@MikroTik] > /export
jan/02/1970 00:20:16 by RouterOS 6.36.3
software id = YHRS-316U
add admin-mac=M4:8F:8A:13:82:11 auto-mac=no comment=defconf name=bridge
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
add authentication-types=wpa2-psk management-protection=allowed mode=
dynamic-keys name=profile1 wpa2-pre-shared-key=WeEll45nT
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
disabled=no distance=indoors frequency=auto security-profile=profile1 ssid=
MikroTik-158714 wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address=192.168.88.1/24 comment=defconf interface=ether2 network=
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=wlan1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related”
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=
ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=
wlan1
/system routerboard settings
set cpu-frequency=400MHz
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
After applying configuration, connection to mAP 2n is lost, notebook does not get IP address, end with 169.254.77.132 address without gate. Of course, then there is not connection to internet from notebook.
Could you please suggest-tell me what is wrong?
Or, could you recommend me right guide?
Thank you for recommendations.
