I’m trying to setup Connection Syncing between 2 VRRP members
When enabling Connection Syncing (does not matter if preemption mode is on or off, or if a remote address is specified) it shows a warning on the VRRP interface
Connection Tracking Inactive!
However Connection Tracking is enabled on both nodes (enabled=yes)
RouterOS is 7.18 (both nodes)
Node 2 is identical except priority for vrrp is 100 and ip’s are .252 instead of .251
Tried disabling the drop rule for input chain, made no difference
What am I doing wrong that it states connection tracking is inactive?
I am having the same issue and just opened a support ticket. I was seeing it in the later 7.17 series and now on 7.18.1. I saw in the release notes where they added that message somewhere in the 7.17 series. Was connection tracking really working on 7.16 or just not seeing the message.
Can’t tell if it worked with older releases.
This is a new setup and before setting it up I upgraded to the latest stable release (by lack of a LTS version)
So I’ve never tried connection sync with a version below 7.18
Please keep us updated if you get any response from the support ticket
I can confirm that connection tracking is working with 7.16.2. I have a VRRP setup with connection “Sync. Connection Tracking” activated. Connections established on one partner are visible in the connection table of the second partner.
I broke with version 7.17. I created a bug report on 12.2.25 (SUP-179219) but have not yet received a reply.
Same problem here:
I had two routers with v7.16.1 in a VRRP setup and connection tracking was working. Connections yould be seen on IP-Firewall-Connections on both routers.
I’ve upgraded the backup router to v7.18.2 and now it says “Connection tracking inactive!”
Disabled Connection tracking and immediately enabled it again on both nodes.
Then enabled Connection Sync on the group authority master (VRRP1) on both nodes and it now works without any complaints
Both nodes showed around 1800 connections in the list, no longer a warning
Still running 7.18, did not get around to upgrading yet
7.19.4 works for me. I got broken when updating to 7.17. I tested it again with 7.19.4 and it works without problems. The 7.19 changelog says:
*) vrrp - fixed detection of connection tracking after reboot (introduced in v7.17);
So I guess that is the fix for the issue.
I upgraded my CCR-1009 and CCR-2004 to 7.19.4. After the reboot, the Connection Tracking which I had previously disabled got re-enabled with the correct settings.
