connection without bridge
Hello, how can i make the rb450g to work : eth1(gateway) → eth2, 3, 4 ,5 (lan) without bridge, only in filters. If it is possible. ( Tutorial or something like this. ) .thank you
1 - Put each port into switch mode with one master (eth1?)
2 - Set up individual networks on each interface and use IP routing
What are you trying to achieve?
HY, i do it with masquerade and input and its works.
I am trying to make an isp server with bandwith balance and limit over mac adress.
now if you can help me with this: bandwidth balance and limit over mac adress.
My configuration: RB450G (bandwith balance and limit over MAC ) → Switch Alied Telesys (8000 MAC adress ) → CLient MAC.
