Connectivity between 2 Edge Mikrotik Router
Hello Everyone
I am stuck in one configuration
I have Core router as huawei
and have 3 PPPOE x86 server with mikrotik v7
All 3 edge pppoe server have diffrent private ip pools for pppoe customers.
for example server 1 have 1.1.1.0/24 and server 2 have 1.1.2.0/24
if i connect to server 1 then i can only get access of ip pool 1.1.1.0/24.
is there any configuration where i can access both server pools
i required this to open routers of pppoe customer which is on private ip
Hi there. Can you post the config of 2 of the routers, removing the sensitive bits?
