Connectivity issue in 5.6 v
Dear Sir
We have a problem with a Point to point Connectivity .we are using Rb411 with 108 mbps Card and router version is 5.6 v .the Connectivity between the device is 75db to 78 db the distance between the devices is 11KM line of site is clear problem is we are unable to ping client side but client can ping our device and he cant access data The connectivity is ok when we check .but he still unable to access .when the 2 devices will reboot manually then only he can access the data for an 1 hour after that the same problem repeating
The connectivity is going from switch to device and all other clients which connected from switch can able to access net another links which are the same mikrotik devices that dosent have problem so pls send the solution
Thanks Regards
Ravi Shankar
Apollo Online
India
