Connectivity issues between devices after roaming
I have a setup of a Hex RB750Gr3 (7.16.2) and a couple of Unifi UAP AC Pro. The one UAP is connected to a switch that is in ether4 of the hEX, and the other to a switch that is in ether5. Both switches are just dumb ones.
If I have two devices on e.g. the upstairs AP and I move on downstairs for one of the devices to roam to the AP downstairs, I will lose connectivity to the other device - I can see how pinging stops to work. After a little while, seemingly random, connectivity suddenly comes back. I’ve tried with multiple devices and the time it takes varies.
If I connect both APs to the same switch, there are no trouble which is why I suspect the router.
The config of the hEX is pretty default, I see nothing in the bridge or port config that should be causing issues. ARP config etc. is default:
    add comment=defconf name=bridge port-cost-mode=short
    add comment=defconf name=WAN
    add comment=defconf name=LAN
    add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 internal-path-cost=10 path-cost=10
    add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
    add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
    add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
    /interface detect-internet
    set detect-interface-list=all
Does anyone have any pointer for what I can try to troubleshoot this?
You described using PING in your diagnosis, as you are roaming from one AP to another…
Did you PING a local Device or something on the Internet like 8.8.8.8?
Secondly, do you see something in the Logfiles of the Router as you are roaming from one AP to another ?
I’m pinging the other device, connected to the AP. The entire problem is losing connectivity to this device or any other under same circumstance
did you solve your Problem. Looks like i have very similar issue.
Never had any troubles with old Capsman, but with CapsV2 i don’t seem i can get it working.
BR
