Connectivity to all customers MT's
Hello there,
i was wondering, as I am on it to establish connectivity to all my customers MT’s (to see weather the main GW is online, possibility to connect to that particular subnet…) what would be the ‘best’ (in a sense of a ‘easy’ setup, not using much resources and so on) way to define and use such way of ‘control’ ?
My intention was to install a CHR online and to enable SSTP connectivity to all customers MT’s where i would be able to see their connection (online ok/not ok) and be able to connect to their local subnet.
How have you guys solved it?
tx
Korg
SSTP or L2TP and some routing rules could definitely do this.
Why do you want to connect to their subnet?
Hi and tx for your answer.
i want to be able to admin their network.. like ‘this is not working…’ or ‘pls change wlan password’…
sstp is less secure isnt it?
