Consequence of new wireguard interface per peer
considering a setup where you have a central wireguard concentrator (eg. a ccr2116_12g_4s) where all wireguard road-warriors connect to ( offices spread around the country with no fixed ips). Let’s say you have up to 500 branch offices you would like to connect:
When configuring the central device what are the resource and system implications of actually generating a new wg-sub-intrerface per office?
In the end there will be about 500 wg interfaces? Do you have any experience with setups like this and are there any non obvious heads-up?
Thx 1000x,
Mischa
I don’t know, good question. I suspect it be worse that the publish IPSec specs since WG has no hardware encryption support. How much, no clue, be curious myself…
Configuration	                       1400 byte	512 byte	64 byte
    	                                 Mbps	kpps	Mbps	kpps	Mbps.    kpps
256 tunnels	AES-256-CBC + SHA256	366.2	4101.4	670	2744.3	670.4	343.2
I agree, how well it scales is an unknown but concur that sounds like routing with hardware encryption territory.
Don’t think I will reach anywhere close to 500, but I am using a RB100AHx4 with ~30 roadwarriors.
The router is interconnected via WG with 45 other Mikrotiks, but traffic is minimal most of the time, with spikes to several hundred Mb/s from each peer twice a day, lasting anywhere from 15 to 30 minutes.
Resource utilization while traffic is under 100 Mb/s is minimal. When pushing close to 600-700 Mb/s WG traffic, my poor 1100AHx4 shows its age and is pretty much maxed out.
WIth no traffic, I see no diference between with or without WG peers.
If you are not going to have large transfers 24/7 between offices, I dare to say a CCR2116 will handle it pretty well.
