considering load balancing load of each ISP, is it possible?
mikrotik has a way of balancing load with 2 different isp charges
examples
wan1 (30 Mb) --------->
! -------> Mikroik ------> Client
wan2 (15 Mb) --------->
WAN2 If this 90% of its cargo and the 50% WAN1 to send traffic to WAN1, do not send one to each wan connection as it does with pcc, this would be the similar to what you do with eigrp cisco.
The overhead of a wan is producce several clients make great downloads and agree to the Internet the same output.
sorry for my bad English, I hope to be as clear and understandable
You’d still want to use PCC. You don’t have to use PCC with just two rules for two ISPs. Extend it to three rules, but mark with the connection mark for ISP1 on the first two. That way ISP1 gets twice as many connections as ISP2, perfectly balancing 2:1.
The only that changes are these two lines from the manual at http://wiki.mikrotik.com/wiki/Manual:PCC:
add chain=prerouting  in-interface=LAN connection-mark=no-mark dst-address-type=!local \
    per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
    per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
becomes
    per-connection-classifier=both-addresses:3/0 action=mark-connection new-connection-mark=ISP1_conn
    per-connection-classifier=both-addresses:3/1 action=mark-connection new-connection-mark=ISP1_conn
    per-connection-classifier=both-addresses:3/2 action=mark-connection new-connection-mark=ISP2_conn
