I have Microtik CCR-1036 that had failed I have transferred everything across to another router but I would like to access the router in it’s current state to compare how this failed with the working configuration of the router that has replaced this one. The only way I can access the old router is via console cable please can you confirm how to set this up so I can extract the failed config for comparison with the working configuration. I have a serial to RJ45 cable
I don’t understand the problem…
- Do you have console cable?
- Do you have Putty or any other terminal emulator?
