How can I get an output of all rules ?
I´m at ip / firewall - but now I should enter the name of a rule - but that´s what I search for - how should I enter it?
I need a list of all definied rules and need to delete one of them?
How can I do that (list and delete)?
From /ip firewall, type ‘rule’ then the name of the chain e.g. input.
‘pr’ will then show a list of rules in that chain. ‘remove’ followed by the rule number will delete the specified rule.
Personally, I find it easier to use Winbox to manipulate the firewall.
Regards
Andrew
thank you - that works! I don´t have winbox and don´t know where to download.
normis
4
enter your router’s IP address in a Web browser. There you will get Winbox.
No, there is my hotspot startpage where the users can login
normis
6
check router’s services menu (/ip service print) see what port you have for www. if you have 8080 then type
http://ip:8080 in your browser, where IP is the IP of the router.
/ip service print works. Now I got it - thanks.
