console, ssh and terminal login fails
hello,
we have this now the 2nd time that we can not access a router via ssh, terminal (in winbox) or serial console. i remember i have read about such thing before but cant find it now in the forum. the only way we where able to get this resolved was a reboot. this happened 2 times on a x86 router with ROS 5.20 and also on a RB1100AHx2 ROS 5.22. on the x86 device also winbox keeps failing which was also mentioned before. we used to be able to just stop the winbox service via ssh login and start it again but thats no option now any more. anybody having the same issue ? any suggestion as to how to fix it ?
thanks
Jan
http://forum.mikrotik.com/t/terminal-not-responding/60552/1
http://forum.mikrotik.com/t/problems-ssh-and-terminal-x86-ros-5-18-and-up/59296/1
OMG… since September and still the same issue ? I see nothing related to a fix in this direction in the Change-log from ROS 5.20. The support file creation does not finish on the RB1100AHx2, the CPU goes up to 100% for a while and that’s it. Still no console at all.
Regards
Jan
