constant disconnects and slow uploads...
I have thre AP’s, all with the same issue. each AP has anywhere from 4 to 10 clients on it, and anyone below a -75 disconnects pretty regularly and has slow upload speeds. Even some client that have signals as high as -68 will disconect! According to Ubiquiti, I should be able to have client connecting as low as a -85!!! I simply dont see how this is supposed to work. Can anyone shed some light on this. Here are the settings of the AP and the Client unit:
AP:
/ interface wireless
set wlan1 name=“wlan1” mtu=1500 mac-address= arp=enabled
disable-running-check=no radio-name=“WEBSPINNERRADIO1” mode=ap-bridge
ssid=“WebSpinnerAP1” area=“” frequency-mode=manual-txpower
country=no_country_set antenna-gain=0 frequency=2427 band=2ghz-5mhz
scan-list=default rate-set=configured supported-rates-b=“”
supported-rates-a/g=24Mbps basic-rates-b=“” basic-rates-a/g=24Mbps
max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default
periodic-calibration-interval=60 burst-time=disabled dfs-mode=none
antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
proprietary-extensions=post-2.9.25 hide-ssid=no security-profile=security
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=long
compression=no allow-sharedkey=no comment=“” disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=yes enable-polling=yes framer-policy=best-fit
framer-limit=1420
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“”
unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none
static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
add name=“security” mode=dynamic-keys authentication-types=wpa2-psk
unicast-ciphers=tkip group-ciphers=tkip wpa-pre-shared-key=“”
wpa2-pre-shared-key=“thundertrash113” tls-mode=no-certificates
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
Client:
disable-running-check=no radio-name=“00156D9329CE” mode=station
country=no_country_set antenna-gain=0 frequency=2422 band=2ghz-5mhz
supported-rates-a/g=18Mbps,24Mbps basic-rates-b=“”
basic-rates-a/g=18Mbps,24Mbps max-station-count=2007 ack-timeout=dynamic
tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=WebSpinnerSecurity disconnect-timeout=3s
on-fail-retry-time=100ms preamble-mode=long compression=no
set wlan1 enable-nstreme=yes enable-polling=yes framer-policy=none
framer-limit=3200
add name=“WebSpinnerSecurity” mode=dynamic-keys authentication-types=wpa2-psk
wpa2-pre-shared-key=“thundertrash113” eap-methods=passthrough
tls-mode=no-certificates tls-certificate=none static-algo-0=none
static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none
static-key-2=“” static-algo-3=none static-key-3=“”
Try putting the power settings to default and turn off nstreme.
Also, you might want to consider upgrading to 2.9.26, they have fixed alot of bugs and haven’t published them. I know 2.9.46 helped fix alot of issues i had.
Matt
What is your noise floor?
You have done a very common thing. You have messed up the rates. It is a big mistake to change settings without understanding what they mean. I suggest you default the entire box and start over. The goo news is that everything will work fine when you go back to defaults.
