Dear friends
I own a WAP LTE kit (RBwAPR-2nd&R11e-LTE) and was working with no problem using 7.13.4 firmware.I decided to update the OS from 7.13.4 to 7.15 through automatic update (in winbox). After download was finished the router entered rebooting state as normal.Now I am no longer able to work with router as the router keeps rebooting.
The Ethernet interface also keeps connecting and disconnecting every 2-5 seconds therefore there is now way to connect to the router.I tried every possible solution from forum but with no luck.
I can’t even use netinstall as the connectivity get lost every couple of second.So I am simply in a dead-ended situation.
Any help is highly appreciated as I am in a really stressful situation. ![]()
Regards
