Hello:
all were consulted to see if their experience can be directed to choose the hardware.
I need to mount a radio with troughput of 35/40mbps full duplex, using nstreme2. He tested with RB600 and cards minipci UBiQUiTi XR5, with just over 40 mbps of entry and exit TCP, but the test was laboratory, and in the real world may not be as simple well, I’m thinking about using dual antennas PACIFIC WIRELESS polarity mark of 32.5 dbi, distance to cover is 34Kms, and at this point, my current radio link is a pair of RB333 with XR5 and antennas of 32.5 dbi PACIFICi polarity simple, with a troughput max of 32mbps. Im Thank their contributions.
Hi, you can use Alix2C2 board with ROS or a PC for more throughtput. Also you can use new routerboards. It is possible that you can achieve more bandwith.
Martín.
