consultant?
i sent email to 25 consultant no one answer?
what is Your Problem?
You can post here, maybe someone will answer.. :slight_smile:
consultants are for hire. did you pay all of them :slight_smile: ?
And what about consultants who are also suppliers will their advice or recommendations for equipment be Mikrotik first or the equipment from other manufacturers which they have in stock ??
http://forum.mikrotik.com/t/2-isp-load-divide/31648/1
i need solution for this…
about money no problem ..i need one help me
this is my email: slaimanroumie@hotmail.com
i sent 25 emails to cunsultnat no one answer..
The consultants list consists of people for hire. If you want free support from your supplier, use the suppliers contact page, not the consultant list. The list contains contact information specifically for premium support.
i can pay…
did you write the same as here, or you actually explained what you want? please post here, what is the task. maybe somebody will help.
I see that you have not even explained the issue correctly. Make a new thread, not post in somebody else’s question. Make proper description, not just “not working”. If you want help, you need to make a clear description of your problem, and include configuration. Make a new topic !
