consume all the ip address on RB951ui interface
hello every one..!
so is there is a tool or any program that we can use in windows 10 to run out all the ip address range in an interface..?
like Yersinia in kali linux..?
Mikrotik related, this hacking tool request???
If you want to know all used IP addresses and open ports … there is “Advanced IP scanner” , or even “Advanced port scanner” for Windows 10.
There is an “IP scan” tool in RouterOS. (in ROS 6.48.6, but can be even earlier).
If you want to do nasty things like with Yersinia. https://linuxsecurity.expert/tools/yersinia/
Go and find your tools. https://www.hackingloops.com/top-12-windows-penetration-testing-tools/. Most testing tools are Linux based.
If you come on my networks, I’ll get you for sure. You better stay in your own ethical hacking lab.
If you do this at work, or on a network that is not yours, have a written permission before you even start using these
Moderator edit: Quote removed. Do not quote yourself or preceding post. Use just “Post Reply”.
very thanksful Mr bpwl ..well..lol..i’m from white hat people. yet i want to know how many ip address the RB951ui can give to it’s clients before it’s goes down.
About 4,000,000 and then the memory runs out, and max 750 IP/s
Hello Mr rextended so to refreash this post.. what you mean by 4,000,000
Continue all here:
http://forum.mikrotik.com/t/maximum-number-of-ips-that-can-be-provided-by-rb951ui/161040/1
