Container does not start
Hello, I have followed the guide to install containers but although the Pihole container has been extracted correctly, it remains stopped and even if I press start it does not start, in the Log I do not see that it indicates anything. It makes an attempt to start but then stops again.
Configuration attached
# 1970-01-02 04:18:54 by RouterOS 7.13.3
# software id = TS8L-SN85
# model = RBD52G-5HacD2HnD
# serial number = HF5091BX5VV
/container mounts
add dst=/etc/pihole name=etc_pihole src=/usb1-part1/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/usb1-part1/etc-dnsmasq.d
/disk
set usb1 type=hardware
add parent=usb1 partition-number=1 partition-offset=512 partition-size=\
    "15 724 445 184" type=partition
add admin-mac=78:9A:18:72:1B:96 auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
add name=dockers
/interface veth
add address=172.17.0.2/24 gateway=172.17.0.1 gateway6="" name=veth1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/container
add envlist=usb1-part1 interface=veth1 mounts=etc_pihole,dnsmasq_pihole \
    root-dir=usb1-part1/pihole start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1/pull
/container envs
add key=TZ name=pihole_envs value=Europe/Madrid
add key=WEBPASSWORD name=pihole_envs value=password
add key=DNSMASQ_USER name=pihole_envs value=root
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=*6 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=*7 internal-path-cost=10 \
    path-cost=10
add bridge=dockers interface=veth1
    192.168.88.0
add address=172.17.0.1/24 interface=dockers network=172.17.0.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes servers=172.17.0.2
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat src-address=172.17.0.0/24
add action=dst-nat chain=dstnat dst-address=192.168.88.1 dst-port=888 \
    protocol=tcp to-addresses=172.17.0.2 to-ports=80
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
Try to enable logging for container (/container set 0 logging=yes), start and see if anything is logged from container in ROS logs.
Done
execve: No such file or directory
I guess something went wrongv with image extraction or there is some problem with accessing usb disk partition; remove container, check if root directory is deleted and delete mount directories if exists, remove leading / in src mount directories (eg. /usb1-part1/etc → usb1-part1/etc) and create new container.
Check also if can actually write file on that usb disk partition (usb1-part1), if you did not already, upload some file on it and try to read it or download it back and check if same file content.
Do the following to make sure everything works:
  1. Check if 172.17.0.2 is pingable
  2. Check in File / Disks if usb1-part1 does exists. You’re pointing everything to this drive / partition but sometimes when you reformat a pen drive it sticks to USB1 (instead of usb1-part1).
  3. Re-format the USB drive otherwise and see (2). Make sure the partition is correctly named usb1-part1 or usb1 and adjust your container script to refer to the correct path (pull / mounting etc.)
  4. Check your container. You made an error in with the envlist. If should point to pihole_envs instead you pointed to usb1-part1
  5. I’m not sure if the container code is simplified in this output but it should (ofcourse) have remote-image = pihole/pihole:latest. Otherwise nothing will be downloaded / extracted.
/container
